[mapserver-users] Raster Image Projection Problems
    Hankley, Chip
    Chip.Hankley at GASAI.Com
    Wed Sep 18 07:28:36 PDT 2002
Check out
http://mapserver.gis.umn.edu/doc36/proj.html#NAD27%20/%20Pennsylvania%20Sout
h
Since your units are in FEET, you need to use the to_meter parameter.
    proj=lcc
    lat_1=39.933333333
    lat_2=40.800000000
    lat_0=39.333333333
    lon_0=-77.750000000
    x_0=609601.219
    y_0=0.000
    ellps=clrk66
    datum=NAD27
    to_meter=0.3048006096
    no_defs
-----Original Message-----
From: Shaik Anwar Hussain [mailto:shussain at atsincorp.com]
Sent: Wednesday, September 18, 2002 8:21 AM
To: Mapserver-Users (E-mail)
Cc: Ben Lewis
Subject: [mapserver-users] Raster Image Projection Problems
Hi List,
          I am having the problem with my raster image display. Does any one
can help me what is wrong in my projection definetion.  When i load this
raster image using ARCMAP its showing in the PA exact place.
 These are my projection definitions.
 Map level projection definition
          PROJECTION
                    "proj=poly"
                    "ellps=GRS80"
                    "lon_0=77.75w"
                   "lat_0=40.925n"
                   "units=m"
          END
Layer definition
	   LAYER
	   NAME "I99-07"
	   TYPE raster
	   DATA "I99-07.tif"
	   STATUS default
	   PROJECTION
                  "proj=lcc"
                  "lat_1=39.933333333"
                  "lat_2=-77.750000000"
                  "lat_0=39.333333333"
                  "lon_0=40.800000000"
                  "x_0=609601.219"
                  "y_0=0.000"
                  "ellps=clrk66"
                 "datum=NAD27"
                 "units=m"
                 "no_defs"
               END
	 END # LAYER
 The Projection definition for the raster layer is  Pennsylvania South
NAD27  Feet.
I am using Apache web server, Windows 2000 and
MapServer version 3.6.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
Thanks for your help.
Anwar
www.atsincorp.com
More information about the MapServer-users
