[mapserver-users] Raster Image Projection Problems
Sean Gillies
snchrstnglls at yahoo.com
Wed Sep 18 13:58:21 EDT 2002
Anwar,
I see that in your layer projection you are defining
'units=m' when you should be defining 'units=f' (feet)
You'll probably catch this error by the time you see
my mail :)
Sean
--- Shaik Anwar Hussain <shussain at atsincorp.com>
wrote:
> Hi List,
> I am having the problem with my raster
> image display. Does any one
> can help me what is wrong in my projection
> definetion. When i load this
> raster image using ARCMAP its showing in the PA
> exact place.
> These are my projection definitions.
> Map level projection definition
> PROJECTION
> "proj=poly"
> "ellps=GRS80"
> "lon_0=77.75w"
> "lat_0=40.925n"
> "units=m"
> END
> Layer definition
> LAYER
> NAME "I99-07"
> TYPE raster
> DATA "I99-07.tif"
> STATUS default
> PROJECTION
> "proj=lcc"
> "lat_1=39.933333333"
> "lat_2=-77.750000000"
> "lat_0=39.333333333"
> "lon_0=40.800000000"
> "x_0=609601.219"
> "y_0=0.000"
> "ellps=clrk66"
> "datum=NAD27"
> "units=m"
> "no_defs"
> END
> END # LAYER
> The Projection definition for the raster layer is
> Pennsylvania South
> NAD27 Feet.
> I am using Apache web server, Windows 2000 and
> MapServer version 3.6.0 OUTPUT=GIF OUTPUT=PNG
> OUTPUT=JPEG OUTPUT=WBMP
> SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT INPUT=EPPL7 INPUT=POSTGIS
> INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> Thanks for your help.
> Anwar
> www.atsincorp.com
__________________________________________________
Do you Yahoo!?
Yahoo! News - Today's headlines
http://news.yahoo.com
