[mapserver-users] line layer label angle changes
Sandor Csaba
c.sandor at emla.hu
Fri Sep 20 12:30:56 EDT 2002
Thanks, it solved the problem. Although I had troubles compiling freetype1
on Solaris (had to use --disable-nls --enable-static whatever these mean)
and also naturally (not for me until today) I had to recompile gd too.
Csaba
At 07:48 20/09/2002 -0400, you wrote:
>This is a freetype 2 issue, just get libttf-1.3.1 and you problems
>should go away.
>-Steve W.
> http://iMapTools.com
>On 20 Sep 2002 at 11:45, Sandor Csaba wrote:
> > Hi All,
> > I want to label streets with their names. It works fine on my windows
> > box (downloaded binaries: ms36gif_gdal_pg_wms.zip). On a Solaris box
> > (the real Internet server, mapserv 3.6.1 CGI, Freetype2, PNG support)
> > the labels are randomly rotated around the same label point.
> > Anybody had similar problems? Can this be a Freetype1 vs. 2 issue?
> > I use the following label definition in the mapfile
> > LABEL
> > COLOR 0 0 0
> > TYPE TRUETYPE
> > FONT arial
> > SIZE 10
> > ANTIALIAS true
> > POSITION AUTO
> > PARTIALS TRUE
> > MINFEATURESIZE 1
> > FORCE FALSE
> > BUFFER 3
> > ANGLE AUTO
> > END
> > Thanks,
> > Csaba
> > {Kornyezeti Management es Jog Egyesulet
> > {Environmental Management and Law Association
> > {www.emla.hu
> > {1076 Budapest
> > {Garay u. 29-31
> > {Hungary
> > {Tel/fax: 36-1-3228462, 36-1-3529925
> > {Mobil: 06-20-949-1447
{www.emla.hu
{1076 Budapest
{Garay u. 29-31
{Hungary
