[mapserver-users] line layer label angle changes
gisweb at lmi.net
gisweb at lmi.net
Fri Sep 20 14:26:05 EDT 2002
Combating the same problem with incorrect label angles (on FreeBSD), I also
recompiled gd with references to freetype-1.3.1, but the mapserver configure
couldn't find it. The compile and make still ran, but the resulting mapserv
program doesn't recognize truetype parameters. Suggestions?
Here's the configure command and resulting output:
./configure --prefix=/usr/home/gisweb/local --with-gd=/usr/home/gisweb/local --w
ith-freetype=/usr/home/gisweb/local/include/freetype --enable-force-freetype1 --
enable-runpath --with-proj --with-tiff
loading cache ./config.cache
checking for gcc... (cached) gcc
checking whether the C compiler (gcc ) works... yes
checking whether the C compiler (gcc ) is a cross-compiler... no
checking whether we are using GNU C... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for c++... (cached) c++
checking whether the C++ compiler (c++ ) works... yes
checking whether the C++ compiler (c++ ) is a cross-compiler... no
checking whether we are using GNU C++... (cached) yes
checking whether c++ accepts -g... (cached) yes
checking for ranlib... (cached) ranlib
checking for flex... (cached) flex
checking for yywrap in -lfl... (cached) yes
checking for bison... (cached) bison -y
checking if compiler supports -R... (cached) no
checking if compiler supports -Wl,-rpath,... (cached) no
checking if compiler supports -Wl,-R... (cached) yes
checking for exp in -lm... (cached) yes
checking how to run the C preprocessor... (cached) gcc -E
checking for ANSI C header files... (cached) yes
checking for strcasecmp... (cached) yes
checking for strncasecmp... (cached) yes
checking for strdup... (cached) yes
checking whether we should include JPEG support...
checking for jpeg_read_header in -ljpeg... yes
using libjpeg from system libs.
checking which version of GD to use...
using libgd from -L/usr/home/gisweb/local/lib -lgd
checking where FreeType is installed...
checking for TT_Init_FreeType in -lttf... no
checking for FT_Init_FreeType in -lfreetype... yes
using libfreetype -lfreetype from system libs.
checking where Zlib is installed...
checking for zlibVersion in -lz... yes
using libz from system libs.
checking where PNG is installed...
checking for png_init_io in -lpng... yes
using libpng from system libs.
checking for gdImageGif in -lc... no
checking for gdImagePng in -lc... yes
checking for gdImageJpeg in -lc... yes
checking for gdImageWBMP in -lc... yes
checking for gdImageStringFT in -lc... no
checking for gdImageStringTTF in -lc... no
checking for gdImageString16 in -lc... yes
checking for gdImageGifPtr in -lc... no
using GD ( -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP) from /usr/home/gisw
eb/local.
checking whether we should include PDF support...
checking for PDF_setlinewidth in -lpdf... yes
checking for PDF_setrgbcolor in -lpdf... yes
checking for PDF_moveto in -lpdf... yes
checking for PDF_curveto in -lpdf... yes
checking for PDF_show_xy in -lpdf... (cached) yes
using libpdf from system libs.
checking whether we should include TIFF support...
checking for TIFFOpen in -ltiff... yes
using libtiff from system libs.
checking whether we should include EPPL7 support...
including EPPL7 support.
checking whether we should include PROJ.4 support...
checking for pj_init in -lproj... yes
checking for pj_transform in -lproj... yes
checking for pj_latlong_from_proj in -lproj... yes
using PROJ.4 from system libs.
checking whether we should include thread safe support...
thread safe support disabled.
checking whether we should include ESRI SDE support...
ESRI SDE support not requested.
checking whether we should compile in MPATROL support...
MPATROL support not requested.
checking whether we should include OGR support...
OGR support not requested.
checking if GDAL support requested... no
checking if PostGIS support requested... no
checking if OracleSpatial support requested... no
checking whether we should include WMS support...
OGC WMS compatibility enabled (-DUSE_WMS).
checking whether we should include WMS Client Connections support...
Compiling with -DIGNORE_MISSING_DATA.
checking whether we should enable debug features...
checking for PHP/MapScript module options...
PHP/MapScript module not configured.
updating cache ./config.cache
creating ./config.status
creating Makefile
Thank you,
Jonathan W. Lowe
Quoting Sandor Csaba <c.sandor at emla.hu>:
> Thanks, it solved the problem. Although I had troubles compiling freetype1
> on Solaris (had to use --disable-nls --enable-static whatever these mean)
> and also naturally (not for me until today) I had to recompile gd too.
> Csaba
> At 07:48 20/09/2002 -0400, you wrote:
> >This is a freetype 2 issue, just get libttf-1.3.1 and you problems
> >should go away.
> >-Steve W.
> > http://iMapTools.com
> >On 20 Sep 2002 at 11:45, Sandor Csaba wrote:
> > > Hi All,
> > > I want to label streets with their names. It works fine on my windows
> > > box (downloaded binaries: ms36gif_gdal_pg_wms.zip). On a Solaris box
> > > (the real Internet server, mapserv 3.6.1 CGI, Freetype2, PNG support)
> > > the labels are randomly rotated around the same label point.
> > > Anybody had similar problems? Can this be a Freetype1 vs. 2 issue?
> > > I use the following label definition in the mapfile
> > > LABEL
> > > COLOR 0 0 0
> > > TYPE TRUETYPE
> > > FONT arial
> > > SIZE 10
> > > ANTIALIAS true
> > > POSITION AUTO
> > > PARTIALS TRUE
> > > MINFEATURESIZE 1
> > > FORCE FALSE
> > > BUFFER 3
> > > ANGLE AUTO
> > > END
> > > Thanks,
> > > Csaba
> > > {Kornyezeti Management es Jog Egyesulet
> > > {Environmental Management and Law Association
> > > {www.emla.hu
> > > {1076 Budapest
> > > {Garay u. 29-31
> > > {Hungary
> > > {Tel/fax: 36-1-3228462, 36-1-3529925
> > > {Mobil: 06-20-949-1447
> {www.emla.hu
> {1076 Budapest
> {Garay u. 29-31
> {Hungary
