[mapserver-users] .map
Lowell Filak
lfilak at medinaco.org
Fri Sep 20 12:49:26 EDT 2002
You could also use the shapefile as the tileindex for the raster layer that includes all the images for a given date/product by using mapscript to change the layer->{tileitem} parameter. The shapefile would have a different field name for each date/product combination and switching the tileitem would change which set of images are used to render the map.
My 2 cents.
Lowell F.
The following message was sent by "John Bennett" <john.bennett at noetix.on.ca> on Fri, 20 Sep 2002 11:00:56 -0400.
> Hi Tyler
> Thanks for the replies. This is a great user group.
> To be more specific, I have 50 different defined areas. Daily new gif files
> will come in showing the crop/soil conditions in each area. Each area may
> have 10 different products (gifs) that define the crop/soil condition. The
> site has to allow the user to select any area, product type and date (from
> 1970 to now) and the crop/soil conditions should be displayed to them.
> Therefore the spatial archive which is being constantly added to may have
> 5,000,000 gif's(I'm exaggerating). (350 days x 10 products x 50 sites x 30
> years).
> I'm thinking a possible way to do this is to have the 50 different areas in
> one shapefile. The user selects which shapefile and selects a date. The
> server gets that date/type and changes the name of the gif in the .map file
> according to the date/type selected by that user. What do you think? Any
> other suggestions?
> John
> -----Original Message-----
> From: Tyler Mitchell [mailto:TMitchell at lignum.com]
> Sent: Thursday, September 19, 2002 5:37 PM
> To: John Bennett
> Subject: Re: [mapserver-users] .map
> You can have as many .map files as you want. But typically 1 file is used
> per "application". Each map file can contain as many layer/dataset
> definitions as you need though! What is actually being updated? Are you
> creating new files that you want to display - or simply modifying existing
> ones? What needs to change in the map file? Do you want to add a new
> layer/dataset (ie. a new shape file or image) or do you simply want the
> updated data to be displayed? It will automatically! Mapserver just
> reads what it is told to and will display any changes once a new request is
> made.
> Feel free to share a bit more of the process with us.
> Tyler
> | | "John Bennett" |
> | | <john.bennett at noetix.on.ca> |
> | | Sent by: |
> | | owner-mapserver-users at lists.|
> | | gis.umn.edu |
> | | 09/19/2002 01:17 PM |
> | To: "Mapserver-Users" <mapserver-users at lists.gis.umn.edu>
> | cc:
> | Fax to:
> | Subject: [mapserver-users] .map
> I'm new to this, therefore a simple question.
> I have a large dataset that is being added to daily, full of shapefiles and
> Gifs. For displaying these files using Mapserver is the protocol to update
> the .map file every time the database is updated (one big .map file, I
> don't
> think so, too big eh!) or make a new .map dynamically for each user
> depending on their request?
> Thanks for the past help.
> John
