[mapserver-users] Loading WMS Image gives strange results (FW: BC OGC Web Map Server Now Available in Test Mode)
Stepan Kafka
stepan.kafka at centrum.cz
Sat Sep 21 08:27:03 EDT 2002
I think, it is caused by 256 color limit in MS 3.6x version. Your colortable
is full so MS chages the colors. Tehe solution is using new RGB supporting
version (3.7).
Stepan Kafka
> -----Pùvodní zpráva-----
> Od: owner-mapserver-users at lists.gis.umn.edu
> [mailto:owner-mapserver-users at lists.gis.umn.edu]za uivatele Tyler
> Mitchell
> Odesláno: 20. záøí 2002 22:48
> Komu: mapserver-users at lists.gis.umn.edu
> Kopie: mcilhagga at dmsolutions.ca
> Pøedmìt: [mapserver-users] Loading WMS Image gives strange results (FW:
> Has anyone got imagery from this WMS source to display properly? The
> colours are all messed up when I load it with MapServer
> It reminds me of a radarsat image I once saw... :) but it should just be a
> b/w orthophoto. Unless I messed up somewhere along the line, I
> assume it's
> a WMS/mapserver issue - will mapserver handle WMS images that are > 8 bit
> depth?
> Here's my layer info.
> LAYER
> NAME BCtest
> TYPE RASTER
> STATUS DEFAULT
> CONNECTIONTYPE WMS
> CONNECTION
> "http://slkapps2.env.gov.bc.ca/servlet/com.esri.wms.Esrimap?VERSIO
> N=1.0.0&REQUEST=map&LAYERS=TRIM%20Orthomosaic%20Overview&FORMAT=gi
> f&BGCOLOR=0x000000"
> METADATA
> "wms_srs" "epsg:42102"
> "wms_timeout" "1000"
> END
> END
> ----- Forwarded by Tyler Mitchell/Lignum on 09/20/2002 01:41 PM -----
> | | "Ross, Michael SRM:EX" |
> | | <Michael.Ross at gems7.gov.bc.ca> |
> | | Sent by: |
> | | owner-geoconnections_cgdi-dev at CCRS.|
> | | NRCan.gc.ca |
> | | 09/13/2002 06:03 PM |
> | To: geoconnections_cgdi-dev at geoconnections.org
> | cc: "Yazdani, Rostam SRM:EX"
> <RYAZDANI at Victoria1.gov.bc.ca> |
> | Fax to:
> | Subject: BC OGC Web Map Server Now Available in Test
> Mode |
> Hi All.
> The Base Mapping and Geomatic Services (BMGS) Branch of the BC Ministry of
> Sustainable Resource Management is pleased to announce the availability of
> our BC OGC Web Map Server on a test basis. BC OGC WMS lets you browse a
> seamless topographic map of British Columbia with a spectacular,
> orthorectified air photo mosaic as a backdrop. The topographic map is
> actually three different scales, 1:6 000 000, 1:250 000, and
> :20 000
> Terrain Resource Information Management (TRIM) 1: 20 000. The map you view
> varies automatically with your zoom level. The orthomosaic is a 1:20
> compressed version of TRIM orthophotography which is in black and white
> with
> one metre pixel resolution.
> Initially, the orthomosaic is turned off. To turn it on, select
> Layers from
> the map menu bar, then turn on the orthomosaic layer. We also
> recommend you
> turn off the water bodies layer so lakes and ponds are outlined, not
> colour-filled.
> Forest Cover is also available with provincial coverage. Other
> layers will
> be added in the future.
> For a demo of an OGC-compliant web map viewer accessing the BC OGC WMS,
> copy
> the URL from ogcdemo1.txt <http://home.gdbc.gov.bc.ca/dim/ogcdemo1.txt>
> into your favourite web browser and go.
> If you are running an OGC-compliant Web Map Server that supports service
> chaining (or cascading), you can use any of our data layers as
> your basemap
> and add your own layers to create your own custom web map service. Our OGC
> Web Map Server is located at
> http://slkapps2.env.gov.bc.ca/servlet/com.esri.wms.EsrimapHYPERLINK
> "http://slkapps2.env.gov.bc.ca/servlet/com.esri.wms.Esrimap" .
> <http://slkapps2.env.gov.bc.ca/servlet/com.esri.wms.EsrimapHYPERLINK >
> We have an important demo next Thursday so would appreciate hearing from
> those who have other BC data and have tried to cascade to our new server.
> geoconnections_cgdi-dev mailing list
> website: http://cgdi-dev.geoconnections.org/
> mailing list: http://cgdi-dev.geoconnections.org/mailinglist/
> email: geoconnections_cgdi-dev at geoconnections.org
