[mapserver-users] I'm hitting some max threshold?!?!
woodbri at swoodbridge.com
Mon Sep 23 19:55:52 EDT 2002
Mike,
check out map.h it has the limits defined in it. You need to up the
limits and recompile.
-Steve W.
On 23 Sep 2002 at 15:08, Mike Smith wrote:
> Hello,
> I'm hitting some maximum that's built-in to Mapserver and I'm not
> sure which one. I have a map file with 52 layers and 352 classes. My
> page works fine (for the most part) except that I cannot load more
> than 14 layers at once. That 15th layer blows up my whole page when I
> try to load it. With one exception...I've got these 8 layers that
> have classes defined inside them using "EXPRESSION" to sub-divide the
> layer by a certain field. I can load all these type of layers,
> regardless of whether or not I exceed the 14 layer limit, but I cannot
> view load more than 14 of my regular layers (regular meaning ones that
> do not use the "EXPRESSION" keyword to search for class members...that
> may sound weird, but that's the only differentiator between the layers
> that work and the ones that don't work)
> Any ideas what "MAX" value I need to increase in the source code so
> that I can recompile and have this work?
> Thanks,
> Mike
