[mapserver-users] Rosa error (RECENTER)
Yewondwossen Assefa
assefa at dmsolutions.ca
Tue Sep 24 14:11:32 EDT 2002
It seems that the value of the pixels coordinates passed to the zoompoint
function are incorrect. It seems that the values are 0,0 which explains the
shiffting of the map to a lower position.
Ivan Paoluzzi wrote:
> Hi all,
> I have a problem with Rosa applet,recenter doesn't work properly.
> When I click recenter or zoomout button, application doesn't draw my map in
> centre but it's moved in lower, so I can see only half map.
> I use php mapscript and Gmap demo (I have adjust it at my project).
> I haven't changed this section of recenter in PHP3 file of Gmap because I
> don't find where is the problem.
> I have just tried to print the point that I'm using as my center point and
> it's ok, and I think that this point is correctly passed to the operation.
> Any idea?
> Regards
> Ivan
> _________________________________________________________________
> Specisci e ricevi le tue email Hotmail dal tuo cellulare con:
> http://mobile.msn.it
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
