[mapserver-users] What does this error message mean?
woodbri at swoodbridge.com
Wed Sep 25 14:41:49 EDT 2002
Chip,
The generation of my tile indexes is always scripted so I generate
things in a consistent manner. It is possible that I had a typo, but
I checked everything a couple of time before I started changing
things.
Your example is not quite the same as mine, because you used absolute
paths in your tileindex LOCATION field, and I used relative paths.
The source does some gymnastics with chdir and paths to open files
and I suspect that this will get cleaned up when Steve L. cleans up
this code to get rid of chdir calls as part of the thread-safety
cleanup.
I use tileindexes in all my mapfiles, so it was a surprise when I ran
into this problem.
-Steve
On 25 Sep 2002 at 13:15, Hankley, Chip wrote:
> > It seems that in the mapfile a a tileindex must be specified
> > relative to the SHAPEPATH item and may not be specified as an
> > absolute path. And further more all TILEINDEX LOCATION values must
> > be relative to the location of the TILEINDEX location.
> ??? I do this all the time w/ no problem:
> SHAPEPATH "D:\DATA\"
> LAYER
> NAME "HILLSHADE100"
> MAXSCALE 1000000
> MINSCALE 500000
> TYPE RASTER
> STATUS DEFAULT
> TILEINDEX "D:\temp\HILLSHADE\HILL100.shp"
> TILEITEM "Location"
> END
> And LOCATION is the fullpath to the images.
> Windows, Mapserver.exe (CGI) and PHP MapScript, IIS.
> chip
