[mapserver-users] Re: PythonMapscript Installation
Norman Vine
nhv at cape.com
Wed Sep 25 17:13:12 EDT 2002
Grit Schuster writes:
> I changed the mapscript.i file as suggested in the WIKI and the setup.py
too.
> But I always get a swig error and syntax errors (../mapscript.i:68. Syntax
> error in input.
> ../mapscript.i:74. Syntax error in input.).
> When I used the original mapscript.i file of the mapserver-3.6.1 source,
> I could compile the pythonMapscript. But I got the following error:
> error: command 'gcc' failed with exit status 1
> Any ideas to solve these problem. Thanks in advance.....
I reworked my distutils script a bit and placed it and
a patched version of mapscript.i
http://www.vso.cape.com/~nhv/files/python/mapscript/3.6.1/
HTH
Norman
