[mapserver-users] GDAL TIFF fun - two supposedly identical builds....
woodbri at swoodbridge.com
Wed Sep 25 23:10:37 EDT 2002
Antti,
Do a ldd on mapserver and the php_mapscript.so on both boxes and see
if it reports any differences. What OS are you running these boxes
under. If Linux they might have different versions of rpms loaded.
-Steve
On 26 Sep 2002 at 11:55, Antti.Roppola at brs.gov.au wrote:
> OK,
> I have two (supposedly) identical boxes running PHP Mapscript (3.6.0
> and 3.6.1) with GDAL (1.1.7) support. The same source data and PHP
> application has been mirrored from box A to B. The same TIFFs work on
> box A, but not box B.
> Box A:
> MapScript Version ($Revision: 1.104 $ $Date: 2002/04/24 20:37:32 $)
> MapServer version 3.6.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> INPUT=EPPL7 INPUT=JPEG INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> Box B:
> MapScript Version ($Revision: 1.104.2.1 $ $Date: 2002/06/03 14:19:53
> $) MapServer version 3.6.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> Viz, from this and looking at the config.status in each compile
> ("--without-tiff"), they do not support TIFF natively but through
> GDAL. TIFFs will display on box A, but not B, where it seems to bail
> as soon as it tries to $map->draw(). gdal_translate will happily
> convert the offending TIFF to other GDAL formats that do work, so I am
> guessing that the GDAL libaries must be OK. looking at the libraries
> actually linked into php_mapscript.so and libgdal.1.1.so, I can't spot
> any obvious differences either. (both GDALs have TIFF and GEOTIFF set
> to "internal").
> The only smoking gun I can see is that on box B, Mapserver
> config.status is looking for gdal.h in the wrong location (but then
> why would other GDAL formats work OK?)
> Thoughts?
> Antti
