[mapserver-users] Problem with angle labels
Xisco Guaita
xguaita at cesiba.com
Thu Sep 26 07:59:51 EDT 2002
I'm working with street maps. But I've problems with the angle labels of the
street line layer.
The result.png attached file is a example of this. The street's center lines
have been drawn to show the differences between label and line angles.
I've builded a shapefile for testing purpose. It has a field with angles
from 0º to 345º in steps of 15º.
Here's the mapfile layer:
LAYER
NAME labels
TYPE point
DATA "theme1"
status on
LABELcache off
labelangleitem angle #angles from 0º to 345º step 15º
CLASS
text "--------------------"
LABEL
TYPE truetype
FONT Lucida
COLOR 75 75 75
POSITION CR
SIZE 12
END
END
END
and the 360.png attached file is the resulting image. There are some angles
draw incorrectly. Is a problem of graphics libraries? Has anyone had the
same problem, and has you found any solution?
I'm using PHPMapscript 3.6.1, libgd 1.8.4, freetype 2.0, php 4.1.2
Thanks in advance,
Xisco Guaita
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020926/1c0021dd/result.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020926/1c0021dd/360.obj
