[mapserver-users] Problem with angle labels
woodbri at swoodbridge.com
Thu Sep 26 08:29:18 EDT 2002
Xisco,
This is a problem that is caused by the use of freetype 2.0, If you
rebuild GD and mapserver using freetype 1.3.1 this problem will be
resolved.
-Steve W.
http://iMapTools.com
On 26 Sep 2002 at 13:59, Xisco Guaita wrote:
> Hi,
> I'm working with street maps. But I've problems with the angle labels
> of the street line layer.
> The result.png attached file is a example of this. The street's center
> lines have been drawn to show the differences between label and line
> angles.
> I've builded a shapefile for testing purpose. It has a field with
> angles from 0º to 345º in steps of 15º.
> Here's the mapfile layer:
> LAYER
> NAME labels
> TYPE point
> DATA "theme1"
> status on
> LABELcache off
> labelangleitem angle #angles from 0º to 345º step 15º
> CLASS
> text "--------------------"
> LABEL
> TYPE truetype
> FONT Lucida
> COLOR 75 75 75
> POSITION CR
> SIZE 12
> END
> END
> END
> and the 360.png attached file is the resulting image. There are some
> angles draw incorrectly. Is a problem of graphics libraries? Has
> anyone had the same problem, and has you found any solution?
> I'm using PHPMapscript 3.6.1, libgd 1.8.4, freetype 2.0, php 4.1.2
> Thanks in advance,
> Xisco Guaita
