[mapserver-users] Problem with angle labels
gisweb at lmi.net
gisweb at lmi.net
Thu Sep 26 16:40:10 EDT 2002
Xisco,
Any or all of the following steps might help if you need to configure mapserver
on a machine with both freetype 1.x and freetype 2.x on it...
Problem summary:
System: FreeBSD
Access: No root access, but local builds okay
Mapserver version: 3.6.1
Goal: Build mapserver with true type support.
Issue: Machine has an existing version of Freetype 2.x. The ./configure
routine recognizes the Freetype 2.x rather than the (required) Freetype 1.x even
when statically pointed to the Freetype 1.x libraries.
Problem solution:
All of the following steps were required to successfully build mapserver in
the above environment...
1) Compile GD 1.8.4 and Freetype 1.3.1 to local directories.
2) In the .login, add:
# Added for mapserver purposes:
setenv LD_LIBRARY_PATH /path/to/libttf.so.4.0
# End of mapserver additions.
(It may also be necessary to establish links to the "lib" directory for
files in the "include" directory. If you get errors that say "such-and-such
file does not exist", but you know the files do exist in the "include"
directory, try establishing a hard or soft link of the same name in the "lib"
directory...)
3) Configure mapserver with the following parameters (plus any others you
want):
./configure --prefix=/path/to/libraries
--with-gd=static,/path/to/libraries
--with-freetype=/path/to/freetype
--enable-force-freetype1
--enable-runpath
--with-proj
--with-tiff
4) Edit the resulting mapserver Makefile as follows:
# These originally pointed to root-only system directories.
# Change them to your local installation directories.
LIB_INSTALL=/usr/home/gisweb/local/lib/
HEADER_INSTALL=/usr/home/gisweb/local/include/mapserver-3.5/
# Proj.4 distribution (cartographic projection routines).
#PROJ_INC <-- originally blank. Needed the reference as shown on line below.
PROJ_INC=-I/usr/local/include
PROJ_LIB= -lproj
PROJ= -DUSE_PROJ -DUSE_PROJ_API_H
# GD distribution (graphics library GIF and/or PNG support). (REQUIRED)
GDFONT_OBJ=gd-1.2/gdfontt.o gd-1.2/gdfonts.o gd-1.2/gdfontmb.o
gd-1.2/gdfontl.o gd-1.2/gdfontg.o
GD_INC= -I/usr/home/gisweb/local/lib
#GD_LIB= -ljpeg -lfreetype -lpng -lz <-- originally refers to -lfreetype.
GD_LIB= -lm -lgd -lpng -lz -ljpeg -lttf
GD= -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_TTF
GD_STATIC = /usr/home/gisweb/local/lib/libgd.a
# TIFF distribution (raster support for TIFF and GEOTIFF imagery).
(RECOMMENDED)
TIFF_INC=
#TIFF_LIB= -ltiff -ljpeg -lpng -lz -lfreetype <-- originally has -lfreetype
TIFF_LIB= -ltiff -ljpeg -lpng -lz -lttf
TIFF= -DUSE_TIFF
5) From the mapserver-3.6.1 directory containing the modified Makefile, type:
make install
make
6) Typing "./mapserv -v" should return the following (Note "SUPPORTS=TTF"):
MapServer version 3.6.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=SHAPEFILE
These steps eliminated the problem of the incorrect True Type angles when
using the ANGLE AUTO parameter in a LABEL object.
Best of luck,
Jonathan Lowe
Quoting Xisco Guaita <xguaita at cesiba.com>:
> Hi,
> I'm working with street maps. But I've problems with the angle labels of the
> street line layer.
> The result.png attached file is a example of this. The street's center lines
> have been drawn to show the differences between label and line angles.
> I've builded a shapefile for testing purpose. It has a field with angles
> from 0º to 345º in steps of 15º.
> Here's the mapfile layer:
> LAYER
> NAME labels
> TYPE point
> DATA "theme1"
> status on
> LABELcache off
> labelangleitem angle #angles from 0º to 345º step 15º
> CLASS
> text "--------------------"
> LABEL
> TYPE truetype
> FONT Lucida
> COLOR 75 75 75
> POSITION CR
> SIZE 12
> END
> END
> END
> and the 360.png attached file is the resulting image. There are some angles
> draw incorrectly. Is a problem of graphics libraries? Has anyone had the
> same problem, and has you found any solution?
> I'm using PHPMapscript 3.6.1, libgd 1.8.4, freetype 2.0, php 4.1.2
> Thanks in advance,
> Xisco Guaita
