[mapserver-users] Two questions
Ivan Paoluzzi
tesimap at hotmail.com
Fri Sep 27 19:41:50 EDT 2002
I have just done these things because before I used Mapserever 3.5
precompiled. And font worked correctly.
This is sections of my map file where is these things that you wrote me:
NAME assi
STATUS ON
SIZE 600 600
EXTENT 34516.634400379 50299.88405952 67395.339019834 78542.30613897
UNITS meters
SCALE 250000
IMAGECOLOR 236 248 203
SHAPEPATH "data"
FONTSET "data/fonts.txt" <--- I have created a file with font names
that I use
LAYER
NAME assist
TYPE LINE
STATUS ON
DATA assist
TOLERANCE 8
LABELITEM nomevia
LABELMAXSCALE 20000
CLASS
NAME "Assi Stradali"
TEMPLATE "assist.html"
COLOR 0 0 100
LABEL
COLOR 0 0 0
FONT arial <--- font name that I use
TYPE TRUETYPE
SIZE 8
ANTIALIAS TRUE
POSITION AUTO
ANGLE AUTO
MINFEATURESIZE 40
MINDISTANCE 100
PARTIALS FALSE
BUFFER 3
END #LABEL
END # CLASS
HEADER "assist_header.html"
FOOTER "assist_footer.html"
END # LAYER
So I think that the problem is freetype or gd...
Ivan
>From: "Tyler Mitchell" <TMitchell at lignum.com>
>To: mapserver-users at lists.gis.umn.edu
>Subject: Re: [mapserver-users] Two questions
>Date: Thu, 26 Sep 2002 13:11:47 -0700
>At 26-Sep-02 11:58 AM, owner-mapserver-users at lists.gis.umn.edu wrote:
> > Hi all,
> > I have two questions.
> > i)I have compiled mapserver 3.5 on Win XP, I think correctly because I
> > haven't message error. But when I test mapserv.exe on my project I have
>this
> > error:
> > loadlabel(): Unknown identifier. Keyword FONT is not valid without
> > TrueType font support.
> > But If I change section of truetype font, in map file, with bitmap font
>my
> > project work correctly.
> > So I think that the problem is freetype or gd compiled with freetype,but
>I
> > didn't have problem when I have compiled these libraries.
> > Any idea?
>There are three things that you need to get the truetype fonts working.
>This may be in the map file/symbol documentation, but here's my spin.
>1) specify FONTSET (I put mine right under the IMAGECOLOR line in the top
>of my map file) and point it to a text file lists two things - a font
>"name" and the location of the truetype font filename. (i.e. arial.ttf)
>2) In your LABEL Object for the layer you have a line:
>FONT <font name>
>With "name" as in point 1
>3) Right after that line I put in a line to specify the type of font. I
>assume you were missing this.
>TYPE truetype
>Does that work for you? I copied the ttf files I wanted into a folder by
>the map file.
_________________________________________________________________
Chiacchiera con gli amici online, prova MSN Messenger:
http://messenger.msn.it
