[mapserver-users] POSTGIS parse error
Alexander Pucher
pucher at atlas.gis.univie.ac.at
Mon Sep 30 05:42:21 EDT 2002
Hi Thomas,
Thomas Haechler wrote:
>Hi Alex
>I recently had exactly the same problem. Did you perhaps restart your
>database server and forgot to allow TCP/IP connections, i.e. forgot to
>use the -i option when starting postmaster?
Well, I restart it on a regular basis, since it runs on my personal
laptop ;-) To answer your question, no, I didn't forget to include the
-i option, everything runs as normal.
>You can find the posting here:
>http://mapserver.gis.umn.edu/wilma/mapserver-users/0208/msg00091.html
>Read also Tyler's note on this:
>http://mapserver.gis.umn.edu/wilma/mapserver-users/0208/msg00093.html
>Btw, I have made very good experiences with the new version of
>mappostgis.c from the 3.7 version, where you get much more detailed
>error messages. See:
>http://mapserver.gis.umn.edu/wilma/mapserver-users/0209/msg00300.html
>Hope this helps you,
Thanks for that.
It managed to get it running again by adding the password=xxxx to the
CONNECTION line in my mapfile. But to be honets, I'm not happy with this
solution.
Why do I have to include my PostgreSQL password now and not in the past?
Apart from that, I don't like to hardcode any passwords in human
readable files.
regards,
alex
>Alexander Pucher wrote:
>>Hi,
>>for some strange reason, mapserver fails to select data from my local
>>PostgreSQL DB with this error:
>>Warning*: MapServer Error in msPOSTGISLayerOpen(): Error parsing POSTGIS
>>connection information
>>This was already posted on the list about a year ago, but with no real
>>conclusion.
>>Dave Blasby wrote back then:
>>The message occurs if the postgresql client
>>library returns a
>>"CONNECTION_BAD" when it tries to open a connection.
>>I have to add that everything used to work on my machine without
>>problems until yesterday....
>>Did anyone come across this problem recently?
>>Any suggestions?
>>Regards,
>>alex
