[mapserver-users] Transparent territory radius
Steve Lime
steve.lime at dnr.state.mn.us
Mon Sep 30 17:05:08 EDT 2002
Hmmmm.... What about using a straight circular symbol, and then the
transparency option?
Eg.
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
LAYER
TYPE POINT
SIZEUNITS kilometers
TRANSPARENCY 50
CLASS
SIZE 60
NAME 'ORAC 30km ring'
SYMBOL 'circle'
COLOR 0 0 255
END
END
That *should* get you blue, transparent, circles centered at the points
you want. This needs version 3.6 though.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> "Martin, Daniel" <DMartin at erac.com> 09/30/02 03:24PM >>>
Sorry for the HTML format if you cannot handle it. It's the easiest
way to
get my point across. I'm not even sure the list supports it.
I am trying to create 30 kilometer radius territory rings that are
transparent. I succeeded, but not in the way I want. I created a
PIXMAP
symbol that (when blown up) looks like this:
Dither symbol
Now, when I use that symbol in predefined a POLYGON layer, it looks
like
this:
Great, this is exactly what I want. Except that I have to build the
circle
buffer layer before hand. When the underlying points change (which
happens
almost every week), I have to rebuild the layer manually. So, I
figured I
could use the original point layer this way:
LAYER
TYPE LINE
CLASS
SIZE 60
SYMBOL dither-blue-10_Percent
COLOR 0 0 255
OUTLINECOLOR 10 10 10
END
END
Unfortunately, that looks like this:
Not exactly what I was hoping for. I've tried everything I could find
in
the documentation, the Wiki, and the mailing list archives, but none of
it
worked. Does anyone know how I can accomplish this with a POINT
layer?
Thanks,
Dan Martin
