[mapserver-users] Is it possilbe to compile mapserver sources by mingw?
woodbri at swoodbridge.com
Mon Sep 30 17:08:54 EDT 2002
The the Borland make utility is very close to the Linux make utility.
here is a sample Makefile from a Linux project that I ported over to
Borland Free C/C++ compiler. It is pretty basic but it might be a
good starting place from the borland compiler. The compiler comes
with a predefined include that called BUILTINS.MAK that is in the
Borland install tree and get loaded when make starts up.
Hope this helps,
-Steve
INCLUDE = -I.;"../include"
CFLAGS = -v -DWIN32 $(INCLUDE)
OBJS = main.obj geo.obj placezip2.obj
LIBDIRS = /L.;"../lib"
LFLAGS = -lap -lc -M -ls $(LIBDIRS)
LIBS = stand.lib strtools.lib cgi-util.lib libshp.lib getopt.lib
all : geo.exe mkgeodbf.exe
geo.exe : $(OBJS)
$(CC) $(CFLAGS) $(LFLAGS) -egeo.exe $(OBJS) $(LIBS)
mkgeodbf.exe : mkgeodbf.obj
$(CC) $(CFLAGS) $(LIBDIRS) mkgeodbf.obj $(LIBS)
clean:
rm -f *.obj *.exe
On 30 Sep 2002 at 14:52, Pericles S. Nacionales wrote:
> MSVC++ isn't required to compile MapServer on Win32 platform. You can
> use Mingw or Borland C/C++ (or whatever) if you want, provided you
> know how to make a Makefile script for their particular make program.
> I was actually going to start using Borland's free (not Free Software)
> C/C++ compiler but couldn't find enough time... If I ever do, I'll
> provide a HOW-TO.
> -Perry N.
> On Mon, 2002-09-30 at 14:39, Hisaji ONO wrote:
> > Hello.
> > Compiling mapserver sources for native win32 binaries seems to
> > require
> > VC++.
> > Mingw can't build Win32 binaries?
> > Can someone tell me?
> > Best Regards.
