[Mapserver-users] Where are legend, reference and .qy images
stored? MORE INFO
Ryan, Adam
ARyan at co.linn.or.us
Mon Apr 7 14:02:50 EDT 2003
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C2FD2F.E7640FE0
Content-Type: text/plain;
charset="iso-8859-1"
Paul,
Why not use an absolute imagepath rather than a relative one so there is no
question as to where mapservr is writing to. Use a drive location, not a
web location, ie: c:\apache\...).
Adam Ryan
Linn County
-----Original Message-----
From: Paul Peterson [mailto:pwpeterson at iesc.net]
Sent: Monday, April 07, 2003 9:02 AM
To: Gerry Creager N5JXS; mapserver
Subject: RE: [Mapserver-users] Where are legend, reference and .qy
images stored? MORE INFO
Gerry, et al...
I did some more testing. I discovered to get the ref, leg and *.qy files
stored the IMAGEPATH directory MUST be assigned the ownership and group of
the web server. In my case when I changed both of these to 'apache' the
images were generated and stored, however, again they are showing up in
/var/tmp!!!! They never get displayed along with the map image because the
process tries to get them from /var/www/html/tmp as it should.
My .map file is in /var/www/html/tutorial/s3/
Expected tmp directory /var/www/html/tmp
The IMAGEPATH and IMAGEURL are:
IMAGEPATH "../../tmp/"
IMAGEURL "/tmp/"
Apache serves html from /var/www/html
Paul Peterson
Gerry's response:
May be a 3.7 "feature"... I've not seen image evolution here, either.
gerry
Paul Peterson wrote:
> Rich, Thank you for your response
> I should have been more specific...
> IMAGEURL "/tmp/"
> Apache server html from /var/www/html
> I give the tmp directory +777 permission which is drwxrwxrwx.
> All the images should be placed in /var/www/html/tmp, however, only the
map
> image is. I found the others (ref, leg and .qy) in /var/tmp!
> I add a tmp directory (/var/www/html/tutorial/s3/tmp) and made these
changes
> to IMAGEPATH and IMAGURL:
> IMAGEPATH "tmp/"
> IMAGEURL "/tutorial35/s3/tmp/"
> Again, the only image that shows up there is the map image and I can't
find
> the others anywhere.
> Is this a bug with 3.7?
> Paul
> Rich's response:
> The images for the map, reference map, legend, and query files will all be
> saved to the IMAGEPATH directory, which is relative to the .map file. So
in
> your case it looks like your map file is in /var/www/html/tutorial35 and
> ../../tmp/ would put you at /var/tmp/. Is your webserver aliasing /tmp to
> /var/tmp/? Check the time stamps on the files in /var/www/html/tmp. Try
> seleting everything in both /var/tmp/ and /var/www/html/tmp and then hit
> mapserver and see where the images files appear, because what you describe
> below does not quite make sense.
> Rich
> At 06:02 PM 4/6/2003 -0500, you wrote:
>>Hello all.
>>I wrote yesterday regarding a problem with my legends and reference images
>>not showing up. Does MapServer (3.7) store all generated images in the
the
>>same tmp directory. I am testing out the Tutorial35 demo app and it is
>>located at /var/www/html/tutorial35. I have a tmp directory
>>/var/www/html/tmp where only the map png files are showing up. I was
> trying
>>out the cashed query and discovered that the legend, reference and *.qy
>>files where being stored in /var/tmp.
>>Where in the map file does the directory for the legend, reference and .qy
>>files get set? If MapServer is smart enough to store these files there
why
>>isn't it smart enough to download them from there as well?
>>A snippet of the map file follows:
>>NAME S3EX4
>>EXTENT -97.5 41.619778 -82.122902 49.38562
>>SIZE 400 300
>>SHAPEPATH "../data"
>>FONTSET "../fonts/fonts.list"
>>SYMBOLSET "../symbols/symbols35.sym"
>>WEB
>> HEADER header.html
>> TEMPLATE s3ex4.html
>> FOOTER footer.html
>> IMAGEURL "/tmp/"
>> LOG /var/www/html/mapserver.log
>>END
>>Again the IMAGEPATH and IMAGEURL as defined above work for the map png,
but
>>not the legend, reference ro .qy files.
>>Any ideas what I am doing wrong?
>>Paul Peterson
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Richard W. Greenwood, PLS
> (307) 733-0203
> Rich at GreenwoodMap.com
> www.GreenwoodMap.com
Gerry Creager -- gerry.creager at tamu.edu
Network Engineering -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
Page: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
Content-Type: text/html;
Content-Transfer-Encoding: quoted-printable
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<META NAME=3D"Generator" CONTENT=3D"MS Exchange Server version =
5.5.2653.12">
<TITLE>RE: [Mapserver-users] Where are legend, reference and .qy =
images stored? MORE INFO</TITLE>
</HEAD>
<BODY>
<BR>
<P><FONT SIZE=3D2>Paul,</FONT>
</P>
<P><FONT SIZE=3D2>Why not use an absolute imagepath rather than a =
relative one so there is no question as to where mapservr is writing =
to. Use a drive location, not a web location, ie: =
c:\apache\...).</FONT></P>
<P><FONT SIZE=3D2>Adam Ryan</FONT>
<BR><FONT SIZE=3D2>Linn County</FONT>
</P>
<P><FONT SIZE=3D2>-----Original Message-----</FONT>
<BR><FONT SIZE=3D2>From: Paul Peterson [<A =
HREF=3D"mailto:pwpeterson at iesc.net">mailto:pwpeterson at iesc.net</A>]</FON=
T>
<BR><FONT SIZE=3D2>Sent: Monday, April 07, 2003 9:02 AM</FONT>
<BR><FONT SIZE=3D2>To: Gerry Creager N5JXS; mapserver</FONT>
<BR><FONT SIZE=3D2>Subject: RE: [Mapserver-users] Where are legend, =
reference and .qy</FONT>
<BR><FONT SIZE=3D2>images stored? MORE INFO</FONT>
</P>
<BR>
<P><FONT SIZE=3D2>Gerry, et al...</FONT>
</P>
<P><FONT SIZE=3D2>I did some more testing. I discovered to get =
the ref, leg and *.qy files</FONT>
<BR><FONT SIZE=3D2>stored the IMAGEPATH directory MUST be assigned the =
ownership and group of</FONT>
<BR><FONT SIZE=3D2>the web server. In my case when I changed both =
of these to 'apache' the</FONT>
<BR><FONT SIZE=3D2>images were generated and stored, however, again =
they are showing up in</FONT>
<BR><FONT SIZE=3D2>/var/tmp!!!! They never get displayed along =
with the map image because the</FONT>
<BR><FONT SIZE=3D2>process tries to get them from /var/www/html/tmp as =
it should.</FONT>
</P>
<P><FONT SIZE=3D2>My .map file is in /var/www/html/tutorial/s3/</FONT>
<BR><FONT SIZE=3D2>Expected tmp directory /var/www/html/tmp</FONT>
<BR><FONT SIZE=3D2>The IMAGEPATH and IMAGEURL are:</FONT>
<BR><FONT SIZE=3D2>IMAGEPATH "../../tmp/"</FONT>
<BR><FONT SIZE=3D2>IMAGEURL "/tmp/"</FONT>
</P>
<P><FONT SIZE=3D2>Apache serves html from /var/www/html</FONT>
</P>
<P><FONT SIZE=3D2>Paul Peterson</FONT>
</P>
<BR>
<BR>
<P><FONT =
SIZE=3D2>=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D</F=
ONT>
<BR><FONT SIZE=3D2>Gerry's response:</FONT>
</P>
<P><FONT SIZE=3D2>May be a 3.7 "feature"... I've not seen =
image evolution here, either.</FONT>
</P>
<P><FONT SIZE=3D2>gerry</FONT>
</P>
<P><FONT SIZE=3D2>Paul Peterson wrote:</FONT>
<BR><FONT SIZE=3D2>> Rich, Thank you for your response</FONT>
<BR><FONT SIZE=3D2>></FONT>
<BR><FONT SIZE=3D2>> I should have been more specific...</FONT>
<BR><FONT SIZE=3D2>> My .map file is in =
<BR><FONT SIZE=3D2>> The IMAGEPATH and IMAGEURL are:</FONT>
<BR><FONT SIZE=3D2>> IMAGEPATH "../../tmp/"</FONT>
<BR><FONT SIZE=3D2>> IMAGEURL "/tmp/"</FONT>
<BR><FONT SIZE=3D2>> Apache server html from /var/www/html</FONT>
<BR><FONT SIZE=3D2>> I give the tmp directory +777 permission which =
is drwxrwxrwx.</FONT>
<BR><FONT SIZE=3D2>> All the images should be placed in =
/var/www/html/tmp, however, only the</FONT>
<BR><FONT SIZE=3D2>map</FONT>
<BR><FONT SIZE=3D2>> image is. I found the others (ref, leg =
and .qy) in /var/tmp!</FONT>
<BR><FONT SIZE=3D2>> I add a tmp directory =
(/var/www/html/tutorial/s3/tmp) and made these</FONT>
<BR><FONT SIZE=3D2>changes</FONT>
<BR><FONT SIZE=3D2>> to IMAGEPATH and IMAGURL:</FONT>
<BR><FONT SIZE=3D2>> IMAGEPATH "tmp/"</FONT>
<BR><FONT SIZE=3D2>> IMAGEURL "/tutorial35/s3/tmp/"</FONT>
<BR><FONT SIZE=3D2>> Again, the only image that shows up there is =
the map image and I can't</FONT>
<BR><FONT SIZE=3D2>find</FONT>
<BR><FONT SIZE=3D2>> the others anywhere.</FONT>
<BR><FONT SIZE=3D2>> Is this a bug with 3.7?</FONT>
<BR><FONT SIZE=3D2>> Paul</FONT>
<BR><FONT SIZE=3D2>> =
</FONT>
<BR><FONT SIZE=3D2>> Rich's response:</FONT>
<BR><FONT SIZE=3D2>> The images for the map, reference map, legend, =
and query files will all be</FONT>
<BR><FONT SIZE=3D2>> saved to the IMAGEPATH directory, which is =
relative to the .map file. So</FONT>
<BR><FONT SIZE=3D2>in</FONT>
<BR><FONT SIZE=3D2>> your case it looks like your map file is in =
/var/www/html/tutorial35 and</FONT>
<BR><FONT SIZE=3D2>> ../../tmp/ would put you at /var/tmp/. Is your =
webserver aliasing /tmp to</FONT>
<BR><FONT SIZE=3D2>> /var/tmp/? Check the time stamps on the files =
in /var/www/html/tmp. Try</FONT>
<BR><FONT SIZE=3D2>> seleting everything in both /var/tmp/ and =
/var/www/html/tmp and then hit</FONT>
<BR><FONT SIZE=3D2>> mapserver and see where the images files =
appear, because what you describe</FONT>
<BR><FONT SIZE=3D2>> below does not quite make sense.</FONT>
<BR><FONT SIZE=3D2>> Rich</FONT>
<BR><FONT SIZE=3D2>> At 06:02 PM 4/6/2003 -0500, you wrote:</FONT>
<BR><FONT SIZE=3D2>>>Hello all.</FONT>
<BR><FONT SIZE=3D2>>></FONT>
<BR><FONT SIZE=3D2>>>I wrote yesterday regarding a problem with =
my legends and reference images</FONT>
<BR><FONT SIZE=3D2>>>not showing up. Does MapServer (3.7) =
store all generated images in the</FONT>
<BR><FONT SIZE=3D2>the</FONT>
<BR><FONT SIZE=3D2>>>same tmp directory. I am testing out =
the Tutorial35 demo app and it is</FONT>
<BR><FONT SIZE=3D2>>>located at /var/www/html/tutorial35. I =
have a tmp directory</FONT>
<BR><FONT SIZE=3D2>>>/var/www/html/tmp where only the map png =
files are showing up. I was</FONT>
<BR><FONT SIZE=3D2>> trying</FONT>
<BR><FONT SIZE=3D2>>>out the cashed query and discovered that the =
legend, reference and *.qy</FONT>
<BR><FONT SIZE=3D2>>>files where being stored in /var/tmp.</FONT>
<BR><FONT SIZE=3D2>>>Where in the map file does the directory for =
the legend, reference and .qy</FONT>
<BR><FONT SIZE=3D2>>>files get set? If MapServer is smart =
enough to store these files there</FONT>
<BR><FONT SIZE=3D2>why</FONT>
<BR><FONT SIZE=3D2>>>isn't it smart enough to download them from =
there as well?</FONT>
<BR><FONT SIZE=3D2>>>A snippet of the map file follows:</FONT>
<BR><FONT SIZE=3D2>>>NAME S3EX4</FONT>
<BR><FONT SIZE=3D2>>>EXTENT -97.5 41.619778 -82.122902 =
49.38562</FONT>
<BR><FONT SIZE=3D2>>>SIZE 400 300</FONT>
<BR><FONT SIZE=3D2>>>SHAPEPATH "../data"</FONT>
<BR><FONT SIZE=3D2>>>FONTSET =
"../fonts/fonts.list"</FONT>
<BR><FONT SIZE=3D2>>>SYMBOLSET =
"../symbols/symbols35.sym"</FONT>
<BR><FONT SIZE=3D2>>>WEB</FONT>
<BR><FONT SIZE=3D2>>> HEADER header.html</FONT>
<BR><FONT SIZE=3D2>>> TEMPLATE s3ex4.html</FONT>
<BR><FONT SIZE=3D2>>> FOOTER footer.html</FONT>
<BR><FONT SIZE=3D2>>> IMAGEPATH =
"../../tmp/"</FONT>
<BR><FONT SIZE=3D2>>> IMAGEURL "/tmp/"</FONT>
<BR><FONT SIZE=3D2>>> LOG =
/var/www/html/mapserver.log</FONT>
<BR><FONT SIZE=3D2>>>END</FONT>
<BR><FONT SIZE=3D2>>>Again the IMAGEPATH and IMAGEURL as defined =
above work for the map png,</FONT>
<BR><FONT SIZE=3D2>but</FONT>
<BR><FONT SIZE=3D2>>>not the legend, reference ro .qy =
files.</FONT>
<BR><FONT SIZE=3D2>>>Any ideas what I am doing wrong?</FONT>
<BR><FONT SIZE=3D2>>>Paul Peterson</FONT>
<BR><FONT =
SIZE=3D2>>>_______________________________________________</FONT>
<BR><FONT SIZE=3D2>>>Mapserver-users mailing list</FONT>
<BR><FONT SIZE=3D2>>>Mapserver-users at lists.gis.umn.edu</FONT>
<BR><FONT SIZE=3D2>>><A =
HREF=3D"http://lists.gis.umn.edu/mailman/listinfo/mapserver-users" =
TARGET=3D"_blank">http://lists.gis.umn.edu/mailman/listinfo/mapserver-us=
ers</A></FONT>
<BR><FONT SIZE=3D2>> Richard W. Greenwood, PLS</FONT>
<BR><FONT SIZE=3D2>> (307) 733-0203</FONT>
<BR><FONT SIZE=3D2>> Rich at GreenwoodMap.com</FONT>
<BR><FONT SIZE=3D2>> www.GreenwoodMap.com</FONT>
<BR><FONT SIZE=3D2>> Mapserver-users mailing list</FONT>
<BR><FONT SIZE=3D2>> Mapserver-users at lists.gis.umn.edu</FONT>
<BR><FONT SIZE=3D2>> <A =
ers</A></FONT>
</P>
<BR>
<P><FONT SIZE=3D2>--</FONT>
<BR><FONT SIZE=3D2>Gerry Creager -- gerry.creager at tamu.edu</FONT>
<BR><FONT SIZE=3D2>Network Engineering -- AATLT, Texas A&M =
University</FONT>
<BR><FONT SIZE=3D2>Cell: 979.229.5301 Office: 979.458.4020 FAX: =
979.847.8578</FONT>
<BR><FONT SIZE=3D2>Page: 979.228.0173</FONT>
<BR><FONT SIZE=3D2>Office: 903A Eller Bldg, TAMU, College Station, TX =
77843</FONT>
</P>
<BR>
<P><FONT =
SIZE=3D2>_______________________________________________</FONT>
<BR><FONT SIZE=3D2>Mapserver-users mailing list</FONT>
<BR><FONT SIZE=3D2>Mapserver-users at lists.gis.umn.edu</FONT>
<BR><FONT SIZE=3D2><A =
ers</A></FONT>
</P>
</BODY>
</HTML>
------_=_NextPart_001_01C2FD2F.E7640FE0--
