[Mapserver-users] Proj problems
Daniel Morissette
morissette at dmsolutions.ca
Fri Aug 1 10:11:57 EDT 2003
I just checked the PROJ4 source (pj_latlong.c) and it accepts both:
PROJ_HEAD(latlong, "Lat/long (Geodetic)") "\n\t";
PROJ_HEAD(longlat, "Lat/long (Geodetic)") "\n\t";
According to CVS logs, it was initially called "latlong" and a few days
after the initial implementation the alias for "longlat" was added.
Daniel
Vincent Schut wrote:
>>>There are a bunch of documents on the internet that say proj=longlat
>>>(google for it, you'll be stumped!). I believe they are wrong... However,
>>>if it is in the mapserver docs/wiki somewhere, we should track that down
>>>and have it corrected.
>>I'll try to find the references...
> After some research I found longlat even in my postgis.sql, defining the
> projection parameters for postgis... I guess that longlat works too, then.
> But according to the docs, it should be latlong.
> Cheers,
> Vincent.
