[Mapserver-users] Proj problems
Vincent Schut
schut at sarvision.com
Fri Aug 1 10:43:11 EDT 2003
Daniel,
thanks for checking that this way and ending my confusion. So simple and I
didn't think of it... Time for me to go home and have weekend :-)
On Friday 01 August 2003 16:11, Daniel Morissette wrote:
> I just checked the PROJ4 source (pj_latlong.c) and it accepts both:
> PROJ_HEAD(latlong, "Lat/long (Geodetic)") "\n\t";
> PROJ_HEAD(longlat, "Lat/long (Geodetic)") "\n\t";
> According to CVS logs, it was initially called "latlong" and a few days
> after the initial implementation the alias for "longlat" was added.
> Daniel
> Vincent Schut wrote:
> >>>There are a bunch of documents on the internet that say proj=longlat
> >>>(google for it, you'll be stumped!). I believe they are wrong...
> >>> However, if it is in the mapserver docs/wiki somewhere, we should track
> >>> that down and have it corrected.
> >>I'll try to find the references...
> > After some research I found longlat even in my postgis.sql, defining the
> > projection parameters for postgis... I guess that longlat works too,
> > then. But according to the docs, it should be latlong.
> > Cheers,
> > Vincent.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
