[Mapserver-users] configuration on chroot'ed system
Bill Wheaton
gisgeek at nc.rr.com
Fri Aug 1 21:37:36 EDT 2003
Daniel:
I forwarded this suggestion to the ISP and it solved the problem.
Many, many thanks!
Bill
On Friday, August 1, 2003, at 01:39 PM, Daniel Morissette wrote:
> This looks like the symptoms of a problem we used to have when
> MapServer's broken 'make install' was used. The 'make install' target
> has been replaced in the Makefile in the latest 3.6.x and 4.0 > versions.
> Ask the ISP to look for an old /usr/local/lib/libmap.a and delete it,
> then link php_mapscript.so again and it should link with the correct
> libmap.a, the one that he just compiled.
> Daniel
> Bill Wheaton wrote:
>> Folks--
>> I'm trying to get a phpmapscript/postgis setup going at my ISP
>> (pghoster). Things are basically working, except that the sys admin
>> has upgraded the mapserv executable to 3.6.6, but it is not being
>> recognized by phpinfo() or my scripts.
>> I run phpinfo() (after loading php_mapscript.so) and get the
>> following:
>> MapServer version 3.6.3 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>> SUPPORTS=TTF INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS
>> INPUT=SHAPEFILE
>> When the sys admin at the ISP runs ./mapserv -v, he gets:
>> [root at secure mapserver-3.6.6]# cd
>> /home/virtual/mysite.org/var/www/cgi-bin/
>> [root at secure cgi-bin]# ./mapserv -v
>> MapServer version 3.6.6 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>> SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7
>> INPUT=JPEG INPUT=POSTGIS INPUT=GDAL INPUT=SHAPEFILE
>> Note that ./mapserv -v reports version 3.6.6 (which is what I want),
>> while phpinfo reports version 3.6.3. Since this is a chroot'ed
>> system, I can't run ./mapserv myself from the command line myself.
>> Additional output from phpinfo() shows:
>> _SERVER["DOCUMENT_ROOT"] /home/virtual/site170/fst/var/www/html
>> _SERVER["SITE_CGIROOT"] /home/virtual/site170/fst/var/www/cgi-bin
>> My site's main document root (index.php and the rest of my php code)
>> is in /home/virtual/site170/fst/var/www/html. But again, since it's
>> chroot'ed, I get to it from:
>> /home/myname/mainwebsite_html/index.php (etc.)
>> and the mapserv cgi is in:
>> /home/myname/mainwebiste_cgi/ (and is named mapserv)
>> The mapserv file is there and shows the date at which the sys admin
>> re-built it to ver 3.6.6.
>> Can anyone provide any insights into troubleshooting this problem?
>> Again, to summarize:
>> My scripts are in the right place and mapserv is found and works, but
>> it's not the right version...phpinfo() shows an older version of
>> mapserv, while running ./mapserv -v shows a newer version...What are
>> the places where an incorrect location for mapserv could be
>> referenced? Thanks in advance for any advice.
>> Bill
