[Mapserver-users] configuration on chroot'ed system
    Daniel Morissette
    morissette at dmsolutions.ca
    Fri Aug  1 10:39:33 PDT 2003
This looks like the symptoms of a problem we used to have when
MapServer's broken 'make install' was used.  The 'make install' target
has been replaced in the Makefile in the latest 3.6.x and 4.0 versions.
Ask the ISP to look for an old /usr/local/lib/libmap.a and delete it,
then link php_mapscript.so again and it should link with the correct
libmap.a, the one that he just compiled.
Daniel
Bill Wheaton wrote:
> Folks--
> I'm trying to get a phpmapscript/postgis setup going at my ISP
> (pghoster). Things are basically working, except that the sys admin has
> upgraded the mapserv executable to 3.6.6, but it is not being recognized
> by phpinfo() or my scripts.
> I run phpinfo() (after loading php_mapscript.so) and get the following:
> MapServer version 3.6.3 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=TTF
> INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS INPUT=SHAPEFILE
> When the sys admin at the ISP runs ./mapserv -v, he gets:
> [root at secure mapserver-3.6.6]# cd /home/virtual/mysite.org/var/www/cgi-bin/
> [root at secure cgi-bin]# ./mapserv -v
> MapServer version 3.6.6 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
> SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7 INPUT=JPEG
> INPUT=POSTGIS INPUT=GDAL INPUT=SHAPEFILE
> Note that ./mapserv -v reports version 3.6.6 (which is what I want),
> while phpinfo reports version 3.6.3. Since this is a chroot'ed system, I
> can't run ./mapserv myself from the command line myself.
> Additional output from phpinfo() shows:
> _SERVER["DOCUMENT_ROOT"] /home/virtual/site170/fst/var/www/html
> _SERVER["SITE_CGIROOT"] /home/virtual/site170/fst/var/www/cgi-bin
> My site's main document root (index.php and the rest of my php code) is
> in /home/virtual/site170/fst/var/www/html. But again, since it's
> chroot'ed, I get to it from:
> /home/myname/mainwebsite_html/index.php (etc.)
> and the mapserv cgi is in:
> /home/myname/mainwebiste_cgi/ (and is named mapserv)
> The mapserv file is there and shows the date at which the sys admin
> re-built it to ver 3.6.6.
> Can anyone provide any insights into troubleshooting this problem?
> Again, to summarize:
> My scripts are in the right place and mapserv is found and works, but
> it's not the right version...phpinfo() shows an older version of
> mapserv, while running ./mapserv -v shows a newer version...What are the
> places where an incorrect location for mapserv could be referenced?
> Thanks in advance for any advice.
> Bill
More information about the MapServer-users
