[Mapserver-users] Re: Mapserver/Mapscript and MySQL 4
Matthew Smith
matt at kbc.net.au
Mon Aug 4 22:28:51 EDT 2003
pkishor_98 wrote:
--SNIP--
>>I am using MySQL 4.0.x, so MyGIS mentioned in the Wiki is out, although
>>it would have been the preferred solution.
> why would it have been the preferred solution? The reason I ask -- is there
> something to be achieved by putting your spatial data into a database? is there
> something you can do with it in the db that you can't do with it as shapefiles?
> Essentially, I ask this of myself -- is there any advantage to a specific way, or am I
> going to do it that way only because it is available...
--SNIP--
I'll explain a little further to show why I need the database access:
The actual points are localities - no, they don't move about much ;-)
However, the data that does change is the labels assigned to the points.
The project in question is a community directory; the localities are
just markers and may be displayed as "boat ramp", "hospital", "pizza
shop", etc. This data *is* dynamic, hence my need for database access.
So, the data being read from the .shp would be constant - it's just the
stuff that would normally lurk in a .dbf that changes. (I'm not going
to use DBF access because I've already got a huge MySQL database.)
Cheers
M
Matthew Smith
Kadina Business Consultancy
South Australia
http://www.kbc.net.au
