[Mapserver-users] Re: Mapserver/Mapscript and MySQL 4
pkishor_98
pkishor at geoanalytics.com
Mon Aug 4 23:17:25 EDT 2003
--- In mapserver-users at yahoogroups.com, Matthew Smith <matt at k...> wrote:
> pkishor_98 wrote:
> --SNIP--
> >>I am using MySQL 4.0.x, so MyGIS mentioned in the Wiki is out, although
> >>it would have been the preferred solution.
> > why would it have been the preferred solution? The reason I ask -- is there
> > something to be achieved by putting your spatial data into a database? is there
> > something you can do with it in the db that you can't do with it as shapefiles?
> > Essentially, I ask this of myself -- is there any advantage to a specific way, or am
I
> > going to do it that way only because it is available...
> --SNIP--
> I'll explain a little further to show why I need the database access:
> The actual points are localities - no, they don't move about much ;-)
> However, the data that does change is the labels assigned to the points.
> The project in question is a community directory; the localities are
> just markers and may be displayed as "boat ramp", "hospital", "pizza
> shop", etc. This data *is* dynamic, hence my need for database access.
I would assume that just as a locality might not "move around", its character also
wouldn't change that much... I mean, what are the odds of today's hospital becoming
tomorrow's boat ramp ;-).
In which case, converting the points to a shapefile and then using LABELITEM expr to
label the features would avoid the DBI/DBD overhead.
On the other hand...
> So, the data being read from the .shp would be constant - it's just the
> stuff that would normally lurk in a .dbf that changes. (I'm not going
> to use DBF access because I've already got a huge MySQL database.)
ya... then the DBI/DBD way seems like a good approach.
You are on the right track. Good luck.
