[Mapserver-users] Double labeling in querymap?
Fawcett, David
David.Fawcett at state.mn.us
Tue Aug 5 14:00:18 EDT 2003
I set a MINDISTANCE of 4 and that took care of the problem.
David.
> From: Steve Lime[SMTP:steve.lime at dnr.state.mn.us]
> Sent: Tuesday, August 05, 2003 12:26 AM
> To: mapserver-users at lists.gis.umn.edu; David.Fawcett at state.mn.us
> Subject: RE: [Mapserver-users] Double labeling in querymap?
> That's cause with HILITE the layer is processed twice, once as normal
> and once with only the selected features. With SELECTED the layer is
> only processed once. The label is just getting set in the cache twice.
> One workaround would be to set a value for MINDISTANCE. In most cases
> that wouldn't affect labeling at all and should remove the second label.
> Steve
> Stephen Lime
> Data & Applications Manager
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> >>> "Fawcett, David" <David.Fawcett at state.mn.us> 08/04/03 4:33 PM >>>
> This occurs when the STYLE property of the QUERYMAP object is set to
> HILITE, but does not occurr when I change it to SELECTED.
> David.
> > From: Fawcett, David[SMTP:David.Fawcett at state.mn.us]
> > Sent: Monday, August 04, 2003 4:27 PM
> > To: 'mapserver-users at lists.gis.umn.edu'
> > Subject: [Mapserver-users] Double labeling in querymap?
> > I am not sure if this is a bug or PIBCAK*
> > Version 4.0 beta2 (7/11/03)
> > When I query a point feature, the querymap puts two identical labels
> on the selected point feature, but correctly places only one label on
> the other point features on the map.
> > The point layer only exists once in the MAP file, so I am not querying
> two overlaying instances of the same point.
> > Am I getting a cached label showing up? I really only need to label
> each facility once.
> > Thanks,
> > David.
> > David Fawcett
> > MN Office of Environmental Assistance
> > *Problem Is Between Chair and Keyboard
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
