[Mapserver-users] rotated label
Vincent Schut
schut at sarvision.com
Wed Aug 6 04:02:46 EDT 2003
Hi Siki,
it is a guess, but there were (are?) some problems with font rotation and
certain versions of libGD. If you are not using the latest version (2.0.15 I
think) you might try upgrading and recompiling mapserver using that version
(make sure to use the --with-gd=path/to/gd switch, otherwise it will use the
one that came with php if you compile with --with-php, which certainly will
be an older one). Also, if I remember well, only truetype fonts can be
rotated, so make sure to use truetype fonts. I do not know about a minimal
version number for freetype, but this might be worth checking too.
Cheers,
Vincent.
On Wednesday 06 August 2003 02:11, Siki Zoltan wrote:
> Hi,
> I get into trouble with rotated labels, I tried 3.6.5 3.6.6 4.0
> with freetype 2.1.4.
> layer definition from the map file:
> LAYER
> NAME "streat_names"
> DATA xshp/unev1
> STATUS ON
> GROUP "annotation"
> TYPE LINE
> LABELITEM "NAME"
> LABELMAXSCALE 5000
> CLASS
> COLOR -1 -1 -1
> LABEL
> COLOR 200 0 200
> ANGLE AUTO
> SIZE 12
> FONT timb
> TYPE TRUETYPE
> END
> END
> END
> There is a line in fonts.lst file:
> timb /usr/share/fonts/default/TrueType/timb____.ttf
> I get text where letters are not rotated but the position is
> changed for each characters e.g. a text at 45 degree
> s or e
> a l
> m p
> p m
> l a
> e s
> Any idea?
> Tankx
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
