[Mapserver-users] qstring - multiple values
Steve Lime
steve.lime at dnr.state.mn.us
Wed Aug 6 11:38:16 EDT 2003
Remember that qstring is a valid MapServer expression so it's more
powerful than before, although with that power comes a bit of complexity
and even cumbersomeness. You're not just limited to string matches. So,
to do multiple matches you would craft a logical expression like ([item]
in ('27001','27003',...)). I'm not sure if the in syntax is correct but
you get the idea. If there is enough interest we could look into
supporting expressions like:
EXPRESSION [27001,27003,...]
and having MapServer recognize that as a list to be matched against a
single ITEM. Sort of a shortcut logical expression. It would be
implemented as a new expression type within the software. Thoughts?
Steve
>>> Matthew Smith <matt at kbc.net.au> 08/06/03 09:03AM >>>
Fawcett, David wrote:
> When I had tried something like
'...mycgi?qstring=27001&qstring=27003&qstring=...'
> qstring appears to be set to only one value, the last value set in
the URL.
> David.
Hmm - looks like Mapserver doesn't handle multiples - you may need to
do something with Mapscript unless someone else can advise another way
of doing this (I'm familiar with query strings, not so much with
Mapserver ;-)
On the subject of query strings - can anyone tell me when Mapserver
will
use/accept the semicolon separator rather than the deprecated
ampersand?
It took me AGES to work out why my query strings weren't working
until
I followed an example to the letter and di it the old way.
Cheers
M
Matthew Smith
Kadina Business Consultancy
South Australia
http://www.kbc.net.au
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
