[Mapserver-users] Just display a layer (2) - Excellent - Thanks
harato
harato_1 at yahoo.com
Fri Aug 8 09:04:32 EDT 2003
Excellent !
Big Thanks for your help !
I've made my mapfile example with an other example
(I'm a beginner/newbie...) and now I've delete 0 in
"expression" and I've my map.
Excellent. thanks again for your help
Cheers
Harato
--- Frank Warmerdam <warmerdam at pobox.com> wrote:
> harato wrote:
> > probably my mapfile is wrong (maybe ?)
> > have I need to add projection value ?
> > I've attached my mapfile example, if anyone can
> help
> > me...
> > LAYER
> > NAME "Département"
> > STATUS ON
> > DATA "./dept56"
> > TYPE POLYGON
> > UNITS METERS
> > SIZEUNITS PIXELS
> > TOLERANCE 0
> > TOLERANCEUNITS PIXELS
> > METADATA
> > "Description" "Département"
> > END
> > CLASS
> > NAME "dept56"
> > EXPRESSION "0"
> > SYMBOL 12
> > COLOR 153 255 255
> > OUTLINECOLOR 51 204 255
> > SIZE 1
> > MINSIZE 1
> > MAXSIZE 100
> > END
> > END
> > END
> Harato,
> I would suggest turning the layer status to DEFAULT,
> but the problem I ran
> into with this configuration was your use of
> EXPRESSION "0". If I comment
> that out it renders OK for me in MapServer.
> I don't see anything indicating what variable is
> being used for the
> classification, so I don't know what the EXPRESSION
> is testing, but whatever
> (if anything it is), it doesn't match your
> expression.
> Best regards,
> I set the clouds in motion - turn up | Frank
> Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows |
> http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial
> Programmer for Rent
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
