[Mapserver-users] Help with simple(?) app
Hobbes Zatow
hobbes_zatow at yahoo.com
Fri Aug 8 17:55:32 EDT 2003
Rich - Not sure I follow you on how to make the
changes. Wouldn't the dimensions of each individual
state have to be specified? Below is my current map
file in case it helps. Thanks for any additional
info.
NAME USA
EXTENT -126 30 -66 44
SIZE 400 200
SHAPEPATH "/project/"
LAYER
NAME counties
DATA counties
TYPE POLYGON
STATUS DEFAULT
CLASSITEM 'Aj'
CLASS
EXPRESSION ([Aj] > 95)
COLOR 0 0 0
END
CLASS
EXPRESSION ([Aj] > 90)
COLOR 51 51 51
END
CLASS
EXPRESSION ([Aj] > 75)
COLOR 102 102 102
END
CLASS
EXPRESSION ([Aj] > 50)
COLOR 153 153 153
END
CLASS
EXPRESSION ([Aj] > 25)
COLOR 204 204 204
END
END # end Layer
LAYER
NAME states
DATA states
TYPE POLYGON
STATUS DEFAULT
CLASSITEM 'STATE_NAME'
CLASS
NAME "States"
OUTLINECOLOR 0 0 0
END
END
END # end of map file
--- Richard Greenwood <Rich at GreenwoodMap.com> wrote:
> At 09:47 AM 8/8/2003 -0700, you wrote:
> >I need to create a simple application that displays
> a
> >map of the US, then allows the user to click on a
> >state to get a zoomed-in view of just the one state
> >(without seeing bordering states).
> >I am able to display the US map with mapserver/cgi
> >without a problem, but how do I:
> >1. Display the zoomed-in state w/o bordering
> states?
> >2. Program the "direct to state" zoom in
> capability?
> Using just CGI I would use mode=itemquery. The map
> file should look
> something like:
> QUERYMAP
> STATUS ON
> STYLE SELECTED
> END
> And make two layers:
> Layer
> NAME "STATE" # displays only one state
> TYPE polygon
> DATA states
> STATUS default
> FILTERITEM ID
> Filter "%ID%"
> CLASS
> TEMPLATE mymap.html # Use to
> display map
> OUTLINECOLOR 255 255 0 # Yellow
> SYMBOL 'solid' SIZE 6
> END
> END
> LAYER
> NAME "STATES" # displays all states
> STATUS ON
> TYPE Polygon
> DATA "states"
> CLASS
> TEMPLATE "mymap.html" # Use to
> display attribute data
> SYMBOL "Solid"
> OUTLINECOLOR 0 0 0
> SIZE 2
> END # CLASS
> END
> Both layers use same data.
> Rich
> Richard W. Greenwood, PLS
> Greenwood Mapping, Inc.
> Rich <at> GreenwoodMap <dot> com
> (307) 733-0203
> http://www.GreenwoodMap.com
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
