[Mapserver-users] Install help
woodbri at swoodbridge.com
Mon Aug 11 07:36:51 EDT 2003
Siki,
You need to uninstall the rpm first with:
rpm -e --nodeps gd
rpm -e --nodeps gd-devel
Then build and install gd-2.0.15
-Steve W.
On 11 Aug 2003 at 9:08, Siki Zoltan wrote:
> Hi,
> You may install a package on RedHat from an RPM or from sources.
> The old GD was installed from an RPM, that is way you see it with rpm
> -q You build the new version from sources, so rpm -q can't see it.
> Now you have two versions of GD on your linux box, the old one in the
> /usr and the new one in /usr/local. You must specify the location for
> the configure script of mapserver --with-gd=DIR to force mapserver to
> use the new one. You may remove the old GD with rpm -e package.
> Probably you won't find an rpm for the newest GD (I couldn't).
> So rpm can handle packages installed from .rpm files.
> Zoltan
> On Mon, 11 Aug 2003, Ethan Granger wrote:
> > My system: RedHat 9.0, Apache 2.0.40, PHP 4.2.2
> > I am a linux newbie and I am trying to install mapserver. I noticed
> > that I needed an upgraded GD library than came with my RH9. When I
> > typed the command "rpm -q gd" I got "gd-1.8.4-11" which I isn't good
> > enough according to the instructions. So this is what I did:
> > Downloaded gd-2.0.15 to /root
> > typed "tar -zxvf gd-2.0.15.tar.gz"
> > typed "cd gd-2.0.15"
> > typed "./configure"
> > typed "make"
> > typed "make install"
> > typed "cd /"
> > typed "rpm -q gd" and "I got gd-1.8.4-11"
> > What gives? How come gd was not upgraded? How do I figure out where
> > RH9 installed it and remove it? or overwrite it?
> > thanks for your help.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
