[mapserver-users] OpenGIS CITE
Brent Fraser
bfraser at geoanalytic.com
Tue Aug 12 11:02:56 EDT 2003
Daniel,
I think you are right. ArcExplorer will display data from servers
supporting WMS v1.1.1 or later. I tested ArcExplorer with 17 WMS urls
(switch to courier font to line things up in the table below):
WMS ArcExporer 4.0.1 Java
Version Connects: Shows Data:
1. NASA Landsat http://wmt.jpl.nasa.gov/cgi-bin/wmt.cgi
1.0.0 YES no
2. GeoArctic Nunavut http://www.geoarctic.com/cgi-bin/wmsgeomapcan
1.0.0 YES "msWMSLoadMapParams(): Unsupported output format."
3. B.C. prov WMS
http://slkapps2.env.gov.bc.ca/servlet/com.esri.wms.Esrimap
1.0.0 no
4. Ontario MNR NFIS http://lioib.lio.mnr.gov.on.ca/lioogc/default.asp
1.0.0 no
5. Ontario MNR GeoLoc
http://lioib.lio.mnr.gov.on.ca/lioogc/OGC_ENV1_View.asp
1.0.0 no
6. Agriculture Canada http://linuxgurrl.agr.ca/cgi-bin/mapeco
1.1.0 no
7. Atlas of Canada
http://cgdi-dev.geoconnections.org/cgi-bin/tomatlasmapper
1.1.0 no
8. GeoScience K Net http://cgkn.net/cgi-bin/mswms_cgkn
1.1.0 no
9. DM Solutions http://www2.dmsolutions.ca/cgi-bin/mswms_gmap
1.1.0 no
10. PCI demo data http://gws.pcigeomatics.com/GWSApp/GeoWSServlet
1.1.1 no
11. Canada's Ag
http://dev.geographynetwork.ca/ogcwms/servlet/com.esri.ogc.wms.WMSServlet
1.1.1 YES YES
12. Canada's Basemap
http://k12.esricanada.com/ogcwms/servlet/com.esri.ogc.wms.WMSServlet
1.1.1 YES YES
13. CCRS
http://ceoware2.ccrs.nrcan.gc.ca/cubewerx/cubeserv/cubeserv.cgi
1.1.2 YES YES
14. CTIS 1 http://wms.cits.nrcan.gc.ca/cgi-bin/cubeserv.cgi
1.1.2 YES YES
15. CubeWerx http://www.cubewerx.com/demo/cubeserv/cubeserv.cgi
1.1.3 YES YES
16. Iowa http://komodo.gis.iastate.edu/server.cgi
graphic YES no
17. Boston coast ortho http://coast.mit.edu/wmtserver.cgi
graphic no
Basically not all servers do a good job of implementing the WMS spec, and as
you point out, the client apps (at least the two I tested) are not much
better. I expect CITE will help the general situation, but it will take
some time.
As for the WMS_Version keyword, I agree that it is not good practice, but
given the current chaotic state of servers and clients it may be useful.
The alternative is a wrapper script on the server. Here's an ASP script to
"promote" Mapserver's version number (and take care of specifying the map
file, another problem):
strRequest = Request.ServerVariables("QUERY_STRING")
strURL =
"http://my.server.com/cgi-bin/mapserv.exe?map=C:\Inetpub\wwwroot\MySite\myma
pfile.map&" & strRequest
Dim objHTTP 'As MSXML2.XMLHTTP
Set objHTTP = Server.CreateObject("MSXML2.ServerXMLHTTP")
objHTTP.open "GET", strURL, false
objHTTP.send ""
pos = instr(ucase(strRequest),"REQUEST=GETCAPABILITIES")
if pos = 0 then pos = instr(ucase(strRequest),"REQUEST=CAPABILITIES")
if pos > 0 then
str111 = replace(objHTTP.responseText,"WMT_MS_Capabilities
version=""1.1.0""","WMT_MS_Capabilities version=""1.1.1""")
Response.Write str111 'objHTTP.responseText
else
Response.BinaryWrite objHTTP.responseBody
end if
Set objHTTP = Nothing
Be advised, the script is not well tested, and is bad practice at least
until Mapserver truely supports v1.1.1. On the other hand it does work well
with ArcExplorer.
Brent
----- Original Message -----
From: "Daniel Morissette" <morissette at dmsolutions.ca>
To: "Brent Fraser" <bfraser at geoanalytic.com>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Monday, August 11, 2003 8:51 PM
Subject: Re: [mapserver-users] OpenGIS CITE
> Brent Fraser wrote:
> > How about an optional "WMS_Version " keyword for the metadata section
of
> > the WEB object in the map file? If present, Mapserver would spit out a
> > <WMT_MS_Capabilities version='1.1.1'> tag (or whatever version was given
in
> > the map file). We could use it to get around client/server WMS version
> > incompatibilies. I realize you're working to implement v1.1.1 in
Mapserver
> > , but there could be other client applications coming out that support
only
> > v1.1.2, etc.
> Unfortunately properly supporting version 1.1.1 is not as simple as
> changing the version tag at the top of the capabilities to say 1.1.1.
> There is probably not much more to it (I don't remember the differences)
> and changing the version number may be enough to fool the ArcExplorer
> client but shouldn't be considered a good practice.
> Actually, I'm a bit surprised that you were unable to connect since you
> wrote that both of your clients support WMS 1.0.0 (do they really?).
> MapServer does support V1.0.0 if the clients ask for that version... so
> if those clients did implement WMS version negociation properly then
> they would have picked version 1.0.0. Note that very few clients
> implement WMS version negociation properly, I don't even think our
> MapLab package does... one more reason to not implement hacks in
> MapServer but instead work on fixing the clients to adhere to the spec.
> Daniel
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
