[Mapserver-users] MAXFEATURES and postgis layer
Zamil Murji
Zamil.Murji at divestco.com
Tue Aug 12 12:41:33 EDT 2003
I am trying to get the maxfeatures tag to work with a postgis layer. It just doesn't seem to work. Here is my layer definition:
LAYER
NAME "morewells"
TYPE point
STATUS off
MAXSCALE 8
CONNECTIONTYPE postgis
CONNECTION "user=idc dbname=idc host=sdb2 port=5432"
DATA "the_geom from twell"
CLASSITEM wellid
MAXFEATURES 1
CLASS
COLOR 0 0 0
SYMBOL 6
SIZE 10
MAXSIZE 10
MINSIZE 10
# TEMPLATE "c:\\mapfiles\test.html"
END
END
Am i doing anything wrong? Does maxfeatures also work in nquery mode?
Thanks
zamil
-----Original Message-----
Sent: Tuesday, August 12, 2003 9:10 AM
To: Howard Mark; mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] &WHERECLAUSES=?
Yes there is. Look into the filteritem and filter tags. Both of these can be changed dynamically from the url.
Hope this helps
Zamil
From: Howard Mark [mailto:MHoward at spaceimaging.com]
Sent: Tuesday, August 12, 2003 8:30 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] &WHERECLAUSES=?
Is there any why to dynamically filter for features to be displayed in a
layer using a HTML template (JS/Java) or with a WMS call -- i.e.
&WHERECLAUSES = ??????
I know expressions in map files - I'm talking dynamically.
Thanks,
Mark
This message is intended only for the use of the Addressee and may
contain information that is PRIVILEGED and CONFIDENTIAL.
If you are not the intended recipient, you are hereby notified that any
dissemination of this communication is strictly prohibited. If you have
received this communication in error, please erase all copies of the
message and its attachments and notify Space Imaging immediately.
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
