[Mapserver-users] SunONE chokes on template file
Steve Lime
steve.lime at dnr.state.mn.us
Tue Aug 12 17:32:56 EDT 2003
I too have noticed a problem under very specific circumstances with seg
faults and templates. Am trying to resolve now...
Steve
>>> <Jean-Francois.Doyon at ccrs.nrcan.gc.ca> 08/12/03 12:33PM >>>
Interesting ...
I can't help specifically, but can make a few suggestions:
Since you're running the CGI, this is likely a problem with the
mapserv
executable, unrelated to the webserver (Unless the webserver creates a
bad
CGI environment, though since this si done usually with a shell, it's
hard
to imagine)
What compiler are you using? Gcc or Sun's ? I've got mapserver on
Solaris 8
with GCC working fine (Under Apache)
If you have 4.0, you can use -QUERY_STRING="map=..." (Or is it
-QUERYSTRING
?) as an option to the executable form the command line. With the
proper
query string, you can get mapserver to go through the template parsing,
and
see if it dies there too.
Doesn't provide a solution, but might help find the cause ...
Hope this helps ...
J.F.
-----Original Message-----
From: Martin Weinelt [mailto:mweinelt at planiglobe.com]
Sent: Tuesday, August 12, 2003 12:22 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] SunONE chokes on template file
currently installing a MapServer CGI-based site under Solaris / SunONE
environment. Trying to - to be honest.
With the first occurence of an angular bracket in the template file,
the
server inserts a nice 'segemtation fault' into the document and aborts.
The
maps are generated, though. Nothing in the error log. Any thoughts,
anyone?
Thanks, Martin
--- Martin Weinelt
--- kk+w - digital cartography
--- Kiel, Germany
--- Tel: +49.431.5791165
--- http://www.planiglobe.com
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
