[Mapserver-users] &WHERECLAUSES=? ---- NOW IMAGES!
Howard Mark
MHoward at spaceimaging.com
Tue Aug 12 13:00:20 EDT 2003
Zamil,
I think I've got it. Thanks! Now the next question.
This does not seem to work with image index shapefile layers.
Is there anyway to display images in a tiled index layer by feature
attribute?
Mark
-----Original Message-----
From: Zamil Murji [mailto:Zamil.Murji at divestco.com]
Sent: Tuesday, August 12, 2003 9:10 AM
To: Howard Mark; mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] &WHERECLAUSES=?
Yes there is. Look into the filteritem and filter tags. Both of these can be
changed dynamically from the url.
Hope this helps
Zamil
From: Howard Mark [mailto:MHoward at spaceimaging.com]
Sent: Tuesday, August 12, 2003 8:30 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] &WHERECLAUSES=?
Is there any why to dynamically filter for features to be displayed in a
layer using a HTML template (JS/Java) or with a WMS call -- i.e.
&WHERECLAUSES = ??????
I know expressions in map files - I'm talking dynamically.
Thanks,
Mark
This message is intended only for the use of the Addressee and may
contain information that is PRIVILEGED and CONFIDENTIAL.
If you are not the intended recipient, you are hereby notified that any
dissemination of this communication is strictly prohibited. If you have
received this communication in error, please erase all copies of the
message and its attachments and notify Space Imaging immediately.
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
