[Mapserver-users] MAXFEATURES and postgis layer
Paul Ramsey
pramsey at refractions.net
Tue Aug 12 14:06:58 EDT 2003
Uh, yeah, bottom line is Dave's "short term fix" won't work. I guess
limit statements are illegal in subselects (fair enough). The final
solution will have to be actually adding the maxfeatures logic to
mappostgis, so that the limit get tagged to the end of the complete SQL
call.
P.
Zamil Murji wrote:
> Still no luck...
> Here is my DATA tag:
> DATA "the_geom from (select * from twell limit 1) as foo"
> Any thoughts?
> Returns the following:
> prep_DB(): Query error. Error executing POSTGIS DECLARE (the actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT wellid::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from (select * from twell limit 1) as foo WHERE the_geom && setSRID('BOX3D(-98.8122689312977 28.0409584082397,-98.8045708396947 28.0517352621723)'::BOX3D, find_srid('','twell','the_geom') )'
> Postgresql reports the error ''
> More Help:
> Error with POSTGIS data variable. You specified '<check your .map file>'.
> Standard ways of specifiying are :
> (1) 'geometry_column from geometry_table'
> (2) 'geometry_column from (<sub query>) as foo using unique <column name> using SRID=<srid#>'
> Make sure you put in the 'using unique <column name>' and 'using SRID=#' clauses in.
> For more help, please see http://postgis.refractions.net/documentation.php
> Mappostgis.c - version of June 12/2003.
> Thanks in advance,
> Zamil
> -----Original Message-----
> From: Paul Ramsey [mailto:pramsey at refractions.net]
> Sent: Tuesday, August 12, 2003 11:57 AM
> To: Zamil Murji
> Cc: David Blasby; mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] MAXFEATURES and postgis layer
> That's not a SQL data statement, it's a mapserver data statement:
> DATA "the_geom from (select * from twell limit 1) as the_selection"
> Zamil Murji wrote:
>>Sorry doesn't work...
>>Here is my DATA tag in my layer definition:
>>DATA "the_geom from twell LIMIT 1"
>>Any thoughts?
>>It brought back this:
>>prep_DB(): Query error. Error executing POSTGIS DECLARE (the actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT wellid::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from twell LIMIT 1 WHERE the_geom && setSRID('BOX3D(-98.8122689312977 28.0409584082397,-98.8045708396947 28.0517352621723)'::BOX3D, find_srid('','twell LIMIT 1','the_geom') )'
>>More Help:
>>From: David Blasby [mailto:dblasby at refractions.net]
>>Sent: Tuesday, August 12, 2003 11:17 AM
>>To: Paul Ramsey; mapserver-users at lists.gis.umn.edu
>>Paul Ramsey wrote:
>>>I am guessing that mappostgis.c is ignoring it. The maplayer.c delegates
>>>that feature to the implementation, and the mappostgis.c implementation
>>>says nothing about it. Should be a very easy feature to add.
>>You can also add a "LIMIT n" clause to the SQL in your DATA statement if
>>you want the functionality "right now".
>>dave
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
