[Mapserver-users] MAXFEATURES and postgis layer
Zamil Murji
Zamil.Murji at divestco.com
Tue Aug 12 14:00:42 EDT 2003
Still no luck...
Here is my DATA tag:
DATA "the_geom from (select * from twell limit 1) as foo"
Any thoughts?
Returns the following:
prep_DB(): Query error. Error executing POSTGIS DECLARE (the actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT wellid::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from (select * from twell limit 1) as foo WHERE the_geom && setSRID('BOX3D(-98.8122689312977 28.0409584082397,-98.8045708396947 28.0517352621723)'::BOX3D, find_srid('','twell','the_geom') )'
Postgresql reports the error ''
More Help:
Error with POSTGIS data variable. You specified '<check your .map file>'.
Standard ways of specifiying are :
(1) 'geometry_column from geometry_table'
(2) 'geometry_column from (<sub query>) as foo using unique <column name> using SRID=<srid#>'
Make sure you put in the 'using unique <column name>' and 'using SRID=#' clauses in.
For more help, please see http://postgis.refractions.net/documentation.php
Mappostgis.c - version of June 12/2003.
Thanks in advance,
Zamil
-----Original Message-----
From: Paul Ramsey [mailto:pramsey at refractions.net]
Sent: Tuesday, August 12, 2003 11:57 AM
To: Zamil Murji
Cc: David Blasby; mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] MAXFEATURES and postgis layer
That's not a SQL data statement, it's a mapserver data statement:
DATA "the_geom from (select * from twell limit 1) as the_selection"
Zamil Murji wrote:
> Sorry doesn't work...
> Here is my DATA tag in my layer definition:
> DATA "the_geom from twell LIMIT 1"
> Any thoughts?
> It brought back this:
> prep_DB(): Query error. Error executing POSTGIS DECLARE (the actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT wellid::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from twell LIMIT 1 WHERE the_geom && setSRID('BOX3D(-98.8122689312977 28.0409584082397,-98.8045708396947 28.0517352621723)'::BOX3D, find_srid('','twell LIMIT 1','the_geom') )'
> More Help:
> From: David Blasby [mailto:dblasby at refractions.net]
> Sent: Tuesday, August 12, 2003 11:17 AM
> To: Paul Ramsey; mapserver-users at lists.gis.umn.edu
> Paul Ramsey wrote:
>>I am guessing that mappostgis.c is ignoring it. The maplayer.c delegates
>>that feature to the implementation, and the mappostgis.c implementation
>>says nothing about it. Should be a very easy feature to add.
> You can also add a "LIMIT n" clause to the SQL in your DATA statement if
> you want the functionality "right now".
> dave
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
