[Mapserver-users] line thickness?
    Nick Petersen-Bergeron
    bergeron at zedxinc.com
    Wed Aug 13 12:43:28 PDT 2003
At 08:59 PM 8/13/2003 +0200, Bruce Bushby wrote:
mapserver-users at lists.gis.umn.edu
You can specify line thickness by adding a circular symbol to the layer,
and then changing the size of the symbol.  For example, here's a symbol
declaration:
SYMBOL
   NAME "circle"
   TYPE ellipse
   FILLED true
   POINTS
     1 1
   END
END
and here's a layer you would use it in.
LAYER
         NAME boundary
         TYPE polygon
         DATA ""
         STATUS ON
                 CLASS
                    NAME "boundary"
                    SYMBOL 'circle'
                    SIZE 5
                    OUTLINECOLOR 255 0 0
                    COLOR -1 -1 -1
                 END
         END
Just tailor that layer to suit your needs.  Adjusting the size declaration
in the boundary Class will adjust the thickness of the line.
System Administrator
ZedX Inc.
369 Rolling Ridge Drive
Bellefonte, PA. 16823
More information about the MapServer-users
