[Mapserver-users] Adding a GIF layer to my .map file
Mario Servin
mservin at tecnoaccion.com.ar
Thu Aug 14 15:43:03 EDT 2003
Hi all,
Still I am fooling around with this....
This is my .map fiel can anybody tell me what is wrong this file ? The GIF
image is not shown.
# Start of map file
NAME DEMO
STATUS ON
SIZE 600 600
EXTENT -71.89965056 -41.36073059 -71.08687515 -40.99260904
UNITS DD
SHAPEPATH "Bariloche"
IMAGECOLOR 255 255 255
# you may need to change this to match your MapServer build
IMAGETYPE PNG
# Start of web interface definition (including WMS enabling metadata)
WEB
HEADER demo_header.html
TEMPLATE demo.html
FOOTER demo_footer.html
MINSCALE 1000
MAXSCALE 1550000
IMAGEPATH "set in demo_init.html"
IMAGEURL "set in demo_init.html"
METADATA
WMS_TITLE "UMN MapServer Itasca Demo"
WMS_ABSTRACT "This is the UMN MapServer demonstration application for
Itasca County located in north central Minnesota."
WMS_ACCESSCONSTRAINTS none
# change this value to match your setup
WMS_ONLINERESOURCE "http://mariolaptop/MyPages/itasca/demo_init.html"
WMS_SRS "EPSG:26915"
END
END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
IMAGECOLOR 0 0 0
LABEL
COLOR 255 255 255
SIZE MEDIUM
END
STYLE 1
SIZE 300 10
COLOR 255 255 255
UNITS KILOMETERS
INTERVALS 5
TRANSPARENT TRUE
STATUS TRUE
END
# Start of symbol definitions (we're only using a few)
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
# Start of layer definitions
LAYER
NAME LagoRutas
TYPE POLYGON
STATUS DEFAULT
DATA LagoRutas
CLASS
NAME 'Lago y Rutas'
COLOR 100 150 255
END
END # lago
LAYER
NAME calles
TYPE LINE
STATUS DEFAULT
DATA calles
# CLASS
# NAME 'Calles'
# COLOR 0 0 0
# END
CLASSITEM "NAME"
LABELITEM "NAME"
CLASS
NAME 'Calles'
COLOR 0 0 0
LABEL
COLOR 0 0 0
TYPE BITMAP
SIZE MEDIUM
ANTIALIAS TRUE
POSITION CC
PARTIALS FALSE
MINDISTANCE 300
BUFFER 4
END # end of label
END
END # calles
LAYER # MODIS raster layer begins here
TYPE RASTER
STATUS ON
NAME "modis"
DATA "ImgRow4xCol4.gif"
END # MODIS raster layer ends here
END # Map File
Additionally the ImgRow4xCol4.gfw file is as follows:
0.000313
0
0
0.000313
-71.488229
-40.989377
Where pixel dimensions where measured in GG.GGGGGG
Regards,
Mario
----- Original Message -----
From: "Pericles S. Nacionales" <nacional at cbs.umn.edu>
To: "Mario Servin" <mservin at tecnoaccion.com.ar>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Tuesday, August 12, 2003 2:15 PM
Subject: Re: [Mapserver-users] Adding a GIF layer to my .map file
> You are way ahead of me. The version 4 tutorial isn't available for
> public consumption yet. It isn't complete (but thanks for pointing out
> a raster projection issue that I have almost forgotten). Please don't
> use the tutorial just yet as I don't want to waste time answering
> questions instead of finishing the tutorial.
> The definitive how-to for raster layers is available in the
> documentation section of the mapserver site:
> http://mapserver.gis.umn.edu/doc40/raster-howto.html
> I also recommend browsing through the how-tos for more in depth
> explanations of concepts in MapServer. The tutorial will point you to
> these references when it becomes available.
> -Perry N.
> On Tue, 2003-08-12 at 09:17, Mario Servin wrote:
> > Hi,
> > I followed the MapServer 4.0 Tutorial for puting a layer with a GIF
> > (RASTER type) in my .map file. Well, nothing happened. The image is not
> > shown. Ok, I did not realize that MapServer has no information about
> > georeference of the GIF file, but nothing was mentioned about it in the
> > Tutorial. Could it be the reason that the image is not shown?. Anyway,
how
> > can I georeference my GIF file?
> > Regards,
> > Mario
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Pericles S. Nacionales <nacional at cbs.umn.edu>
> University of Minnesota
