[Mapserver-users] Linux RedHat 9.0 php/mapscript installation
Dylan Keon
keon at nacse.org
Fri Aug 15 03:08:49 EDT 2003
Alexander,
Did you copy /usr/local/php-4.3.2/sapi/cgi/php to your cgi-bin? Or did
you copy another php file to your cgi-bin? Also make sure the php
executable that came with RH9 isn't being called for some reason.
Do you have lines similar to these in your httpd.conf?...
AddType application/x-httpd-php .php .phtml
Action application/x-httpd-php /cgi-bin/php
You might also try removing certain PHP ./configure options one by one,
to see if you can pinpoint the problem.
I'm not familiar with --with-layout=RedHat (in your Apache config).
Make sure that's not doing anything weird. :-)
HTH,
--Dylan
Alexander Shostko wrote:
> Dear List !
> The brief description of the problem:
> I am porting php/mapscript application
> (php-4.3.2/apache-1.3.27)
> from Windows to Linux
> Linux is Red-Hat 9.0, php is 4.3.2, apache is 1.3.28
> installed in /etc/httpd and /var/www/ as typical.
> mapserver-3.6.6
> The installation flags and options are below. All compiles
> fine. But does
> not run at all. It did not even come to
> mapscript. The php itself does not work with apache as cgi .
> When I try to run simple
> <?php
> // nothing works
> dl("php_mapscript.so");
> phpinfo();
> gives
> Warning: Unexpected character in input: '(ASCII=15) state=1 in
> /var/www/cgi-bin/php on line 3395
> Warning: Unexpected character in input: '^B' (ASCII=2) state=1
> in /var/www/cgi-bin/php on line 3395
> Warning: Unexpected character in input: ' in
> Parse error: parse error in /var/www/cgi-bin/php on line 3395
> which means that php simply not working whether I use dl(..) or
> not.
> I tried also httpd-2.0.47 etc. same results. ALso I tried from
> tarball
> (Linux 9.0 installation) of apache/php . Same results.
> The possible options are:
> --Install older / stabler RedHat (8.0 for ex, 9.0 is very new)
> --Install apache 1.3.27 or older
> --try php-4.3.0 or 4.2.x until I have at least apache-php as cgi
> working,
> then put mapscript there.
> Any ideas on which Linux/apache/php/options or simly what I am
> missing ?
> Thanks a lot
> Alex
> Simulation Tech.
> engineer
> The apache is compiled with:
> rm config.cache
> ./configure \
> --prefix=/etc/httpd/ \
> --enable-module=all \
> --enable-shared=max \
> --with-layout=RedHat \
> --disable-rule=WANTHSREGEX=no
> php is compiled with:
> rm config.cache
> ./configure \
> --with-regex=system \
> --with-config-file-path=/etc/httpd/ \
> --enable-safe-mode \
> --enable-force-cgi-redirect \
> --enable-discard-path \
> --enable-versioning \
> --enable-magic-quotes \
> --enable-track-vars \
> --with-gd \
> --with-zlib \
> --with-jpeg \
> --with-ming \
> --with-xml \
> --with-ftp \
> --with-regex=system
> when making make test it tells that:
> CWD : /usr/local/php-4.3.2
> PHP : /usr/local/php-4.3.2/sapi/cli/php
> PHP_SAPI : cli
> PHP_VERSION : 4.3.2
> ZEND_VERSION: 1.3.0
> PHP_OS : Linux
> INI actual : /etc/httpd/php.ini
> More .INIs :
> Extra dirs :
> TIME START 2003-08-15 01:47:20
> The mapscript is compiled with:
> rm -r config.cache
> ./configure \
> --without-tiff \
> --without-eepl \
> --with-jpeg \
> --with-threads \
> --with-proj \
> --with-gdal \
> --with-php=../php-4.3.2 \
> --with-gd=/usr/local \
> --with-freetype=/usr/bin \
> --with-pdf \
> --with-ogr \
> --with-ming \
> --with-wmsclient \
> --with-wfs \
> --with-wfs-client
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
