[Mapserver-users] Mapserver and flash
William A. Bronsema, C.E.T.
bronsema at dmsolutions.ca
Tue Aug 19 08:14:49 EDT 2003
Lars-Göran,
It is fairly easy to view the SWF output using actionscript. Set the
outputformat in the map file to the following:
OUTPUTFORMAT
NAME swf
MIMETYPE "application/x-shockwave-flash"
DRIVER swf
IMAGEMODE PC256
# the following line is used to output all layers in one swf
FORMATOPTION "OUTPUT_MOVIE=SINGLE"
# the following line is used to output all layers individually
#FORMATOPTION "OUTPUT_MOVIE=MULTIPLE"
END
After mapserver has generated the temp swf file(s) you can use the
"loadMovie" actionscript function to load the swf file into a
pre-existing container. For example, create a new swf file with a movie
clip called "clip1" and add the following line in actionscript:
loadMovie ( "http://url/to/swf/mymap.swf", "clip1" );
I use PHP and php_mapscript to help manage the files on the fly and
Flash to manage my actionscript.
I hope this quick overview helps.
Regards,
Bill
Lars-goran Edholm wrote:
> Hi!
> Does anybody have an example of using Mapserver with swf vector output.
> How do i use the swf-actionscript file to view the layers?
> Mvh
> Lars-Göran Edholm tel 026/24 14 36
> 1:e byggnadsinspektör
> Bygg- och miljökontoret
> 811 80 Sandviken
> lars-goran.edholm at sandviken.se
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Applications Developer
DM Solutions Group Inc.
http://www.dmsolutions.ca
e-mail: bronsema at dmsolutions.ca
phone : +1 (613) 565-5056 ext.25
fax : +1 (613) 565-0925
