[Mapserver-users] Mapserver and flash
Geoffrey Rowland
geoffrey.rowland at noaa.gov
Tue Aug 19 09:56:39 EDT 2003
I was playing around with this a bit the other day. Is there a way to
identify features in the swf file? for example if I am displaying a
county layer (from a shapefile), and I want to get the names of the
counties....is that possible using the swf output?
Thanks,
Geoff
William A. Bronsema, C.E.T. wrote:
> Lars-Göran,
> It is fairly easy to view the SWF output using actionscript. Set the
> outputformat in the map file to the following:
> OUTPUTFORMAT
> NAME swf
> MIMETYPE "application/x-shockwave-flash"
> DRIVER swf
> IMAGEMODE PC256
> # the following line is used to output all layers in one swf
> FORMATOPTION "OUTPUT_MOVIE=SINGLE"
> # the following line is used to output all layers individually
> #FORMATOPTION "OUTPUT_MOVIE=MULTIPLE"
> END
> After mapserver has generated the temp swf file(s) you can use the
> "loadMovie" actionscript function to load the swf file into a
> pre-existing container. For example, create a new swf file with a
> movie clip called "clip1" and add the following line in actionscript:
> loadMovie ( "http://url/to/swf/mymap.swf", "clip1" );
> I use PHP and php_mapscript to help manage the files on the fly and
> Flash to manage my actionscript.
> I hope this quick overview helps.
> Regards,
> Bill
> Lars-goran Edholm wrote:
>> Hi!
>> Does anybody have an example of using Mapserver with swf vector output.
>> How do i use the swf-actionscript file to view the layers?
>> Mvh
>> Lars-Göran Edholm tel 026/24 14 36
>> 1:e byggnadsinspektör
>> Bygg- och miljökontoret
>> 811 80 Sandviken
>> lars-goran.edholm at sandviken.se
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Geoffrey Rowland
Technical Officer
Climate Information Project
NOAA Research
Office of Global Programs
http://www.cip.ogp.noaa.gov
Contractor,
RGII Technologies, Inc., a Computer Horizons Company
http://www.rg2.com
Phone: 301-427-2089x186
Fax : 301-427-2082
