[Mapserver-users] Help !!! Mapscript installation nightmare !!
Charlton Purvis
cpurvis at asg.sc.edu
Wed Aug 20 14:48:51 EDT 2003
Try adding
--enable-internal-ld-detect
to your mapserver ./configure.
If that doesn't help, what is your php configuration?
Charlton
> -----Original Message-----
> From: D. Scott Davidson [mailto:davidson at usgs.gov]
> Sent: Wednesday, August 20, 2003 2:34 PM
> To: mapserver-users at lists.gis.umn.edu
> Cc: D. Scott Davidson
> Subject: [Mapserver-users] Help !!! Mapscript installation nightmare
> Hello,
> I have spent an enormous amount of time trying to get php-mapscript to
> work.
> This has truly been a nightmare.
> I have built php-4.3.2 as part of apache_1.3.26 on Solaris 2.8 .
> This builds fine, and php works.
> I then built and installed mapserver-4.0.
> I configured mapserver with this:
> configure --without-tiff --with-proj=/usr/local/lib --with-gdal
> --with-wmsclient --with-gd=/usr/lib
--with-php=/usr/local/include/php/
> It made fine.
> I then copied the mapserver.so to the php directory, edited the
php.ini
> file.
> When running the phpinfo_mapscript.php test file I get these errors:
> Warning: dl(): Unable to load dynamic library
> '/usr/opt/lib/php/extensions/php_mapscript.so' -
> ld.so.1: /usr/local/apache/bin/httpd: fatal: relocation error: file
> /usr/opt/lib/php/extensions/php_mapscript.so: symbol gdImageSetClip:
> referenced symbol not found
> in /www/htdocs/phpinfo_mapscript.php on line 21
> This has been maddening - does anyone know how to fix this ?
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
