[Mapserver-users] Help !!! Mapscript installation nightmare !!
Randy James
rjames57 at yahoo.com
Wed Aug 20 14:50:32 EDT 2003
What version of GD you have? looks like you have to upgrade
to a higher version
Cheers
Randy
--- "D. Scott Davidson" <davidson at usgs.gov> wrote:
> Hello,
> I have spent an enormous amount of time trying to get
> php-mapscript to
> work.
> This has truly been a nightmare.
> I have built php-4.3.2 as part of apache_1.3.26 on
> Solaris 2.8 .
> This builds fine, and php works.
> I then built and installed mapserver-4.0.
> I configured mapserver with this:
> configure --without-tiff --with-proj=/usr/local/lib
> --with-gdal
> --with-wmsclient --with-gd=/usr/lib
> --with-php=/usr/local/include/php/
> It made fine.
> I then copied the mapserver.so to the php directory,
> edited the php.ini
> file.
> When running the phpinfo_mapscript.php test file I get
> these errors:
> Warning: dl(): Unable to load dynamic library
> '/usr/opt/lib/php/extensions/php_mapscript.so' -
> ld.so.1: /usr/local/apache/bin/httpd: fatal: relocation
> error: file
> /usr/opt/lib/php/extensions/php_mapscript.so: symbol
> gdImageSetClip:
> referenced symbol not found
> in /www/htdocs/phpinfo_mapscript.php on line 21
> This has been maddening - does anyone know how to fix
> this ?
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
