[Mapserver-users] Help !!! Mapscript installation nightmare !!
D. Scott Davidson
davidson at usgs.gov
Wed Aug 20 16:33:40 EDT 2003
I appreciate the suggestions. thanks.
I tried to configure mapserver with:
rm config.cache
configure --without-tiff --with-proj=/usr/local/lib
--with-gdal=/usr/opt/bin/gdal-config --with-wmsclient --with-gd=/usr/lib
--with-php=/usr/local/include/php/ --enable-internal-ld-detect
make clean
make
copied php_mapscript.so to its place.
I still got the error:
Warning: dl(): Unable to load dynamic library
'/usr/opt/lib/php/extensions/php_mapscript.so' - ld.so.1:
/usr/local/apache/bin/httpd: fatal: relocation error: file
/usr/opt/lib/php/extensions/php_mapscript.so:
symbol gdImageSetClip: referenced symbol not found in
/www/htdocs/phpinfo_mapscript.php on line 21
My gdal version is gdal-1.1.8.
I configured PHP like this:
./configure --with-system-regex --with-apache=../apache_1.3.26/
--with-pgsql.
There has to be a simple answer here.
Thanks in advance.
"Charlton Purvis"
<cpurvis at asg.sc.edu> To: "D. Scott Davidson" <davidson at usgs.gov>,
Sent by: <mapserver-users at lists.gis.umn.edu>
mapserver-users-admin at lists. cc:
gis.umn.edu Subject: RE: [Mapserver-users] Help !!! Mapscript installation nightmare !!
08/20/2003 01:48 PM
Try adding
to your mapserver ./configure.
If that doesn't help, what is your php configuration?
Charlton
> -----Original Message-----
> From: D. Scott Davidson [mailto:davidson at usgs.gov]
> Sent: Wednesday, August 20, 2003 2:34 PM
> To: mapserver-users at lists.gis.umn.edu
> Cc: D. Scott Davidson
> Subject: [Mapserver-users] Help !!! Mapscript installation nightmare
> Hello,
> I have spent an enormous amount of time trying to get php-mapscript to
> work.
> This has truly been a nightmare.
> I have built php-4.3.2 as part of apache_1.3.26 on Solaris 2.8 .
> This builds fine, and php works.
> I then built and installed mapserver-4.0.
> I configured mapserver with this:
> configure --without-tiff --with-proj=/usr/local/lib --with-gdal
> It made fine.
> I then copied the mapserver.so to the php directory, edited the
php.ini
> file.
> When running the phpinfo_mapscript.php test file I get these errors:
> ld.so.1: /usr/local/apache/bin/httpd: fatal: relocation error: file
> /usr/opt/lib/php/extensions/php_mapscript.so: symbol gdImageSetClip:
> in /www/htdocs/phpinfo_mapscript.php on line 21
> This has been maddening - does anyone know how to fix this ?
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
