[Mapserver-users] MapServer 4 configure problems
Randy James
rjames57 at yahoo.com
Thu Aug 21 17:55:59 EDT 2003
Hi
Seems like i seen some of the error before when i had 2
versions of GD on my machine and did not realize it.
I am now using GD-2.0.15
Hope this helps
Randy
--- Leah Roderman <elrod at oaktownunderground.com> wrote:
> I am trying to configure MapServer 4.0 on RedHat Linux
> 8.0 3.2-7 with gcc v3.2. Earlier this year I had a
> successful compile of MapServer 3.6.4 on the same system,
> running with Apache, PostgreSQL, and PostGIS. If the
> problem described below rings bells for anyone, please
> let me know...
> I'm trying to configure using:
> ./configure \
> --with-gd=/usr/local/lib \
> --with-jpeg=/usr/lib \
> --with-zlib=/usr/lib \
> --with-png=/usr/lib \
> --with-proj=/usr/local/proj \
> --with-freetype=/usr/lib \
> --with-gdal=/usr/bin/gdal-config \
> --with-wmsclient=/usr \
> --with-postgis=/usr/local/pgsql/bin/pg_config \
> --enable-debug \
> --disable-ignore-missing-data \
> And configure complains that it can't find GD. The most
> recent version of this error (shortened to the most
> relevant chunk) is:
> checking where libXpm is installed...
> checking for XpmFreeXpmImage in -lXpm... no
> XPM (libXpm) library cannot be found, possibly
> needed for GD
> checking where libiconv is installed...
> checking for libiconv_open in -liconv... yes
> using libiconv from system libs.
> checking for GD 2.0.12 or higher...
> checking for gdImageSetAntiAliased in -lgd... no
> checking whether GD needs libiconv...
> configure: error: Could not find gd.h or libgd.a/libgd.so
> in /usr/local/lib. Make sure GD \
> 2.0.12 or higher is compiled before calling configure.
> I've doublechecked for GD (this directory is also spec'd
> in ld.so.conf):
> # f gd.h
> ./usr/local/lib/gd.h
> # f libgd.a
> ./usr/local/lib/libgd.a
> I've removed the rpm and rebuilt GD a la the RH8/9 and
> MS37/40b directions at:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MapServerCompilation
> I've installed libiconv after reading
http://lists.gis.umn.edu/pipermail/mapserver-dev/2003-June/000404.html
> but my compile.log has some different content than
> described, including:
> configure:2626: checking whether GD needs libiconv...
> configure:2628: checking for gdImageSetAntiAliased in
> -lgd
> configure:2647: gcc -o conftest -g -O2 conftest.c -lgd
> -ljpeg -L/usr/lib -lfreetype -L/u\
> sr/lib -lpng -L/usr/lib -lz -L/usr/local/lib -liconv
> -lm -lstdc++ 1>&5
> /tmp/cc8Gdwol.o: In function `main':
> /var/dl/mapserver-4.0/configure:2643: undefined reference
> to `gdImageSetAntiAliased'
> collect2: ld returned 1 exit status
> configure: failed program was:
> #line 2636 "configure"
> #include "confdefs.h"
> /* Override any gcc2 internal prototype to avoid an
> error. */
> /* We use char because int might match the return type of
> a gcc2
> builtin and then its argument prototype would still
> apply. */
> char gdImageSetAntiAliased();
> int main() {
> ; return 0; }
> thanks for the help!
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
