[Mapserver-users] HELP!! My Demo is shooting blanks!!
Lowther, David W
dlowther at ou.edu
Fri Aug 22 10:46:28 EDT 2003
Looks like your units don't jive with your extent.
David Lowther
Software Engineer
GEO Information Systems
University of Oklahoma
dlowther at ou.edu
(405) 325-3131
http://www.geo.ou.edu
> -----Original Message-----
> From: Michael Smith [mailto:msmith at sanangelompo.org]
> Sent: Friday, August 22, 2003 9:34 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] HELP!! My Demo is shooting blanks!!
> I have the Itasca demo up and running on windows 2000 IIS 5.
> When I insert my shapefile (tgrds and usa) into the demo and
> change the extents, I get a blank demo screen. Everything
> else looks the same I even have my counties boundary
> reference file appear on the right. Any ideas will be very
> much apppreciated!!!
> Here is my demo_init.html file:
> MAP
> # Start of map file
> NAME "DEMO"
> STATUS ON
> EXTENT 176871 41.619778 -82.122902 49.38562
> #EXTENT -180.0 -90.0 180.0 90.0
> SIZE 600 600
> SHAPEPATH "data"
> IMAGECOLOR 255 255 255
> UNITS DD
> # you may need to change this to match your MapServer build
> #IMAGETYPE PNG
> # Projection definition, consult the PROJ.4 documentation
> for parameter discussion
> #PROJECTION
> # "proj=utm"
> # "ellps=GRS80"
> # "zone=15"
> # "north"
> # "no_defs"
> # OR:
> # "init=epsg:26915"
> #END
> # Start of web interface definition (including WMS enabling
> metadata)
> WEB
> MINSCALE 1000
> MAXSCALE 5550000
> IMAGEPATH "set in cosademo_init.html"
> IMAGEURL "set in cosademo_init.html"
> HEADER "demo_header.html"
> FOOTER "demo_footer.html"
> TEMPLATE "cosademo.html"
> METADATA
> "WMS_TITLE" "UMN MapServer Itasca Demo"
> "WMS_ABSTRACT" "This is the UMN MapServer
> demonstration application
> for Itasca County located in north central Minnesota."
> "WMS_ACCESSCONSTRAINTS" "none"
> "WMS_ONLINERESOURCE"
> "http://192.168.110.21/itasca/cosademo_init.html"
> "WMS_SRS" "EPSG:26915"
> END
> END
> # Start of reference map
> REFERENCE
> STATUS ON
> IMAGE "graphics/cosarefer.gif"
> SIZE 120 120
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> END
> QUERYMAP
> STATUS ON
> SIZE 200 200
> COLOR 255 0 0
> STYLE HILITE
> END
> # Start of legend
> LEGEND
> STATUS ON
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> END
> # Start of scalebar
> SCALEBAR
> STATUS TRUE
> COLOR 255 255 255
> UNITS MILES
> INTERVALS 1
> SIZE 80 2
> STYLE 1
> LABEL
> SIZE tiny
> COLOR 255 255 255
> END
> END
> # Start of symbol definitions (we're only using a few)
> SYMBOL
> NAME "circle"
> TYPE ELLIPSE
> FILLED TRUE
> POINTS
> 1 1
> END
> END
> # Start of layer definitions
> LAYER
> NAME "ctybdpy2"
> STATUS OFF
> DATA "ctybdpy2"
> TYPE POLYGON
> CLASSITEM "cty_name"
> METADATA
> "WMS_TITLE" "County Boundary"
> "WMS_ABSTRACT" "Itasca County boundary shapefile. See
> http://deli.dnr.state.mn.us/metadata/full/ctybdne2.html for
> more information."
> END
> CLASS
> EXPRESSION "Itasca"
> COLOR 225 225 185
> OUTLINECOLOR 128 128 128
> END
> CLASS
> # every other county in the state
> EXPRESSION /./
> COLOR 255 255 255
> END
> END
> LAYER
> NAME "mcd90py2"
> GROUP "cities"
> STATUS OFF
> DATA "mcd90py2"
> TYPE POLYGON
> CLASSITEM "city_name"
> HEADER "mcd90py2_header.html"
> FOOTER "mcd90py2_footer.html"
> # allow GML export
> METADATA
> "WMS_TITLE" "Minor Civil Divisions"
> "WMS_ABSTRACT" "Minor civil divisions for Itasca County.
> (boundaries only)"
> END
> CLASS
> NAME "Cities & Towns"
> EXPRESSION /./
> COLOR 255 225 90
> TEMPLATE "mcd90py2.html"
> END
> END
> LAYER
> NAME "twprgpy3"
> STATUS OFF
> DATA "twprgpy3"
> TYPE POLYGON
> METADATA
> "WMS_TITLE" "Township Boundaries"
> "WMS_ABSTRACT" "Pulic Land Survey (PLS) township
> boundaries for
> Itasca County. See
> http://deli.dnr.state.mn.us/metadata/full/twprgne2.html
> for more information."
> END
> CLASS
> NAME "Townships"
> SYMBOL "circle"
> OUTLINECOLOR 181 181 145
> SIZE 2
> END
> END
> LAYER
> NAME "lakespy2"
> STATUS OFF
> DATA "lakespy2"
> TYPE POLYGON
> TOLERANCE 3
> HEADER "lakespy2_header.html"
> FOOTER "lakespy2_footer.html"
> # allow GML export
> METADATA
> "WMS_TITLE" "Lakes and Rivers"
> "WMS_ABSTRACT" "DLG lake and river polygons for
> Itasca County. See
> http://deli.dnr.state.mn.us/metadata/full/dlglkpy2.html for
> more information."
> END
> CLASS
> NAME "Lakes & Rivers"
> COLOR 49 117 185
> TEMPLATE "lakespy2.html"
> END
> END
> # lakes
> LAYER
> NAME "dlgstln2"
> STATUS OFF
> DATA "dlgstln2"
> TYPE LINE
> TOLERANCE 5
> HEADER "dlgstln2_header.html"
> FOOTER "dlgstln2_footer.html"
> # allow GML export
> METADATA
> "WMS_TITLE" "Streams"
> "WMS_ABSTRACT" "DLG streams for Itasca County. See
> http://deli.dnr.state.mn.us/metadata/full/dlgstln2.html for
> more information."
> END
> CLASS
> NAME "Streams"
> COLOR 49 117 185
> TEMPLATE "dlgstln2.html"
> END
> END
> # streams
> LAYER
> NAME "ctyrdln3"
> GROUP "roads"
> STATUS OFF
> DATA "ctyrdln3"
> TYPE LINE
> MAXSCALE 300000
> METADATA
> "WMS_TITLE" "County Roads"
> "WMS_ABSTRACT" "County roads. (lines only) Derived
> from MNDOT
> roads layer, see
> http://deli.dnr.state.mn.us/metadata/full/dotrdln2.html for
> more information."
> END
> CLASS
> COLOR 0 0 0
> END
> END
> # county roads
> LAYER
> NAME "ctyrdln3_anno"
> GROUP "roads"
> STATUS OFF
> DATA "ctyrdln3"
> TYPE ANNOTATION
> MAXSCALE 300000
> LABELITEM "road_name"
> METADATA
> "WMS_ABSTRACT" "County roads. (shields only)
> Derived from MNDOT
> roads layer, see
> more information."
> END
> CLASS
> SYMBOL "symbols/ctyhwy.gif"
> COLOR 255 255 255
> LABEL
> SIZE TINY
> POSITION CC
> MINDISTANCE 150
> MINFEATURESIZE 40
> COLOR 0 0 0
> END
> END
> END
> # county road annotation
> LAYER
> NAME "majrdln3"
> GROUP "roads"
> STATUS OFF
> DATA "majrdln3"
> TYPE LINE
> MAXSCALE 600000
> METADATA
> "WMS_TITLE" "Highways"
> "WMS_ABSTRACT" "Highways- state, US and interstate.
> (lines only)
> Derived from MNDOT roads layer, see
> more information."
> END
> CLASS
> NAME "Roads"
> COLOR 0 0 0
> END
> END
> # highways
> LAYER
> NAME "majrdln3_anno"
> GROUP "roads"
> STATUS OFF
> DATA "majrdln3"
> TYPE ANNOTATION
> CLASSITEM "road_class"
> MAXSCALE 600000
> LABELITEM "road_num"
> METADATA
> (shields only)
> more information."
> END
> CLASS
> EXPRESSION "3"
> # dummy color
> SYMBOL "symbols/sthwy.gif"
> COLOR 0 0 0
> LABEL
> SIZE TINY
> POSITION CC
> MINDISTANCE 150
> MINFEATURESIZE 50
> COLOR 0 0 0
> END
> END
> CLASS
> EXPRESSION "2"
> # dummy color
> SYMBOL "symbols/ushwy.gif"
> COLOR 0 0 0
> LABEL
> SIZE TINY
> POSITION CC
> MINDISTANCE 150
> MINFEATURESIZE 50
> COLOR 0 0 0
> END
> END
> CLASS
> EXPRESSION "1"
> # dummy color
> SYMBOL "symbols/interstate.gif"
> COLOR 0 0 0
> LABEL
> SIZE TINY
> POSITION CC
> MINDISTANCE 150
> MINFEATURESIZE 50
> COLOR 255 255 255
> END
> END
> END
> # highway annotation
> LAYER
> NAME "airports"
> STATUS OFF
> DATA "airports"
> TYPE POINT
> TOLERANCE 5
> HEADER "airports_header.html"
> FOOTER "airports_footer.html"
> METADATA
> "WMS_TITLE" "Airports"
> "WMS_ABSTRACT" "Airport runways for Itasca County."
> END
> CLASS
> NAME "Airports"
> SYMBOL "circle"
> COLOR 128 255 164
> SIZE 7
> TEMPLATE "airports.html"
> END
> END
> LAYER
> NAME "cities"
> STATUS OFF
> DATA "mcd90py2"
> TYPE ANNOTATION
> LABELITEM "city_name"
> LABELMAXSCALE 500000
> METADATA
> (annotation only)"
> END
> CLASS
> EXPRESSION /./
> COLOR -1 -1 -1
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> POSITION CC
> BUFFER 2
> COLOR 0 0 0
> SHADOWCOLOR 218 218 218
> SHADOWSIZE 2 2
> PARTIALS FALSE
> END
> END
> END
> LAYER
> NAME "tgroads"
> STATUS ON
> DATA "tgrds"
> TYPE LINE
> CLASSITEM "Street"
> UNITS DD
> END
> LAYER
> NAME "usa"
> STATUS DEFAULT
> DATA "usa"
> TYPE POLYGON
> UNITS DD
> END
> END
> Michael Smith, Planner II
> City of San Angelo
> Planning & Development
> 325.657.4210 Fax: 325.481.2648
> Email: msmith at sanangelompo.org
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
