[Mapserver-users] HELP!! My Demo is shooting blanks!!
    Michael Smith
    msmith at sanangelompo.org
    Fri Aug 22 07:33:40 PDT 2003
I have the Itasca demo up and running on windows 2000 IIS 5.  When I insert
my shapefile (tgrds and usa) into the demo and change the extents, I get a
blank demo screen.  Everything else looks the same I even have my counties
boundary reference file appear on the right.  Any ideas will be very much
apppreciated!!!
Here is my demo_init.html file:
MAP
  # Start of map file
  NAME "DEMO"
  STATUS ON
  EXTENT 176871 41.619778 -82.122902 49.38562
  #EXTENT -180.0 -90.0 180.0 90.0
  SIZE 600 600
  SHAPEPATH "data"
  IMAGECOLOR 255 255 255
  UNITS DD
  # you may need to change this to match your MapServer build
  #IMAGETYPE PNG
  # Projection definition, consult the PROJ.4 documentation for parameter
discussion
  #PROJECTION
  #  "proj=utm"
  #  "ellps=GRS80"
  #  "zone=15"
  #  "north"
  #  "no_defs"
  #  OR:
  #  "init=epsg:26915"
  #END
  # Start of web interface definition (including WMS enabling metadata)
  WEB
    MINSCALE 1000
    MAXSCALE 5550000
    IMAGEPATH "set in cosademo_init.html"
    IMAGEURL "set in cosademo_init.html"
    HEADER "demo_header.html"
    FOOTER "demo_footer.html"
    TEMPLATE "cosademo.html"
    METADATA
      "WMS_TITLE"    "UMN MapServer Itasca Demo"
      "WMS_ABSTRACT"    "This is the UMN MapServer demonstration application
for Itasca County located in north central Minnesota."
      "WMS_ACCESSCONSTRAINTS"    "none"
      "WMS_ONLINERESOURCE"
"http://192.168.110.21/itasca/cosademo_init.html"
      "WMS_SRS"    "EPSG:26915"
    END
  END
  # Start of reference map
  REFERENCE
    STATUS ON
    IMAGE "graphics/cosarefer.gif"
    SIZE 120 120
    COLOR -1 -1 -1
    OUTLINECOLOR 255 0 0
  END
  QUERYMAP
    STATUS ON
    SIZE 200 200
    COLOR 255 0 0
    STYLE HILITE
  END
  # Start of legend
  LEGEND
    STATUS ON
    KEYSIZE 18 12
    LABEL
      TYPE BITMAP
      SIZE MEDIUM
      COLOR 0 0 89
    END
  END
  # Start of scalebar
  SCALEBAR
    STATUS TRUE
    COLOR 255 255 255
    UNITS MILES
    INTERVALS 1
    SIZE 80 2
    STYLE 1
    LABEL
      SIZE tiny
      COLOR 255 255 255
    END
  END
  # Start of symbol definitions (we're only using a few)
  SYMBOL
    NAME "circle"
    TYPE ELLIPSE
    FILLED TRUE
    POINTS
       1 1
    END
  END
  # Start of layer definitions
  LAYER
    NAME "ctybdpy2"
    STATUS OFF
    DATA "ctybdpy2"
    TYPE POLYGON
    CLASSITEM "cty_name"
    METADATA
      "WMS_TITLE"    "County Boundary"
      "WMS_ABSTRACT"    "Itasca County boundary shapefile. See
http://deli.dnr.state.mn.us/metadata/full/ctybdne2.html for more
information."
    END
    CLASS
      EXPRESSION "Itasca"
      COLOR 225 225 185
      OUTLINECOLOR 128 128 128
    END
    CLASS
      # every other county in the state
      EXPRESSION /./
      COLOR 255 255 255
    END
  END
  LAYER
    NAME "mcd90py2"
    GROUP "cities"
    STATUS OFF
    DATA "mcd90py2"
    TYPE POLYGON
    CLASSITEM "city_name"
    HEADER "mcd90py2_header.html"
    FOOTER "mcd90py2_footer.html"
    # allow GML export
    METADATA
      "WMS_TITLE"    "Minor Civil Divisions"
      "WMS_ABSTRACT"    "Minor civil divisions for Itasca County.
(boundaries only)"
    END
    CLASS
      NAME "Cities & Towns"
      EXPRESSION /./
      COLOR 255 225 90
      TEMPLATE "mcd90py2.html"
    END
  END
  LAYER
    NAME "twprgpy3"
    STATUS OFF
    DATA "twprgpy3"
    TYPE POLYGON
    METADATA
      "WMS_TITLE"    "Township Boundaries"
      "WMS_ABSTRACT"    "Pulic Land Survey (PLS) township boundaries for
Itasca County. See http://deli.dnr.state.mn.us/metadata/full/twprgne2.html
for more information."
    END
    CLASS
      NAME "Townships"
      SYMBOL "circle"
      OUTLINECOLOR 181 181 145
      SIZE 2
    END
  END
  LAYER
    NAME "lakespy2"
    STATUS OFF
    DATA "lakespy2"
    TYPE POLYGON
    TOLERANCE 3
    HEADER "lakespy2_header.html"
    FOOTER "lakespy2_footer.html"
    # allow GML export
    METADATA
      "WMS_TITLE"    "Lakes and Rivers"
      "WMS_ABSTRACT"    "DLG lake and river polygons for Itasca County. See
http://deli.dnr.state.mn.us/metadata/full/dlglkpy2.html for more
information."
    END
    CLASS
      NAME "Lakes & Rivers"
      COLOR 49 117 185
      TEMPLATE "lakespy2.html"
    END
  END
  # lakes
  LAYER
    NAME "dlgstln2"
    STATUS OFF
    DATA "dlgstln2"
    TYPE LINE
    TOLERANCE 5
    HEADER "dlgstln2_header.html"
    FOOTER "dlgstln2_footer.html"
    # allow GML export
    METADATA
      "WMS_TITLE"    "Streams"
      "WMS_ABSTRACT"    "DLG streams for Itasca County. See
http://deli.dnr.state.mn.us/metadata/full/dlgstln2.html for more
information."
    END
    CLASS
      NAME "Streams"
      COLOR 49 117 185
      TEMPLATE "dlgstln2.html"
    END
  END
  # streams
  LAYER
    NAME "ctyrdln3"
    GROUP "roads"
    STATUS OFF
    DATA "ctyrdln3"
    TYPE LINE
    MAXSCALE 300000
    METADATA
      "WMS_TITLE"    "County Roads"
      "WMS_ABSTRACT"    "County roads. (lines only)  Derived from MNDOT
roads layer, see http://deli.dnr.state.mn.us/metadata/full/dotrdln2.html for
more information."
    END
    CLASS
      COLOR 0 0 0
    END
  END
  # county roads
  LAYER
    NAME "ctyrdln3_anno"
    GROUP "roads"
    STATUS OFF
    DATA "ctyrdln3"
    TYPE ANNOTATION
    MAXSCALE 300000
    LABELITEM "road_name"
    METADATA
      "WMS_ABSTRACT"    "County roads. (shields only)  Derived from MNDOT
more information."
    END
    CLASS
      SYMBOL "symbols/ctyhwy.gif"
      COLOR 255 255 255
      LABEL
        SIZE TINY
        POSITION CC
        MINDISTANCE 150
        MINFEATURESIZE 40
        COLOR 0 0 0
      END
    END
  END
  # county road annotation
  LAYER
    NAME "majrdln3"
    GROUP "roads"
    STATUS OFF
    DATA "majrdln3"
    TYPE LINE
    MAXSCALE 600000
    METADATA
      "WMS_TITLE"    "Highways"
      "WMS_ABSTRACT"    "Highways- state, US and interstate. (lines only)
Derived from MNDOT roads layer, see
http://deli.dnr.state.mn.us/metadata/full/dotrdln2.html for more
information."
    END
    CLASS
      NAME "Roads"
      COLOR 0 0 0
    END
  END
  # highways
  LAYER
    NAME "majrdln3_anno"
    GROUP "roads"
    STATUS OFF
    DATA "majrdln3"
    TYPE ANNOTATION
    CLASSITEM "road_class"
    MAXSCALE 600000
    LABELITEM "road_num"
    METADATA
      "WMS_ABSTRACT"    "Highways- state, US and interstate. (shields only)
information."
    END
    CLASS
      EXPRESSION "3"
      # dummy color
      SYMBOL "symbols/sthwy.gif"
      COLOR 0 0 0
      LABEL
        SIZE TINY
        POSITION CC
        MINDISTANCE 150
        MINFEATURESIZE 50
        COLOR 0 0 0
      END
    END
    CLASS
      EXPRESSION "2"
      # dummy color
      SYMBOL "symbols/ushwy.gif"
      COLOR 0 0 0
      LABEL
        SIZE TINY
        POSITION CC
        MINDISTANCE 150
        MINFEATURESIZE 50
        COLOR 0 0 0
      END
    END
    CLASS
      EXPRESSION "1"
      # dummy color
      SYMBOL "symbols/interstate.gif"
      COLOR 0 0 0
      LABEL
        SIZE TINY
        POSITION CC
        MINDISTANCE 150
        MINFEATURESIZE 50
        COLOR 255 255 255
      END
    END
  END
  # highway annotation
  LAYER
    NAME "airports"
    STATUS OFF
    DATA "airports"
    TYPE POINT
    TOLERANCE 5
    HEADER "airports_header.html"
    FOOTER "airports_footer.html"
    METADATA
      "WMS_TITLE"    "Airports"
      "WMS_ABSTRACT"    "Airport runways for Itasca County."
    END
    CLASS
      NAME "Airports"
      SYMBOL "circle"
      COLOR 128 255 164
      SIZE 7
      TEMPLATE "airports.html"
    END
  END
  LAYER
    NAME "cities"
    STATUS OFF
    DATA "mcd90py2"
    TYPE ANNOTATION
    LABELITEM "city_name"
    LABELMAXSCALE 500000
    METADATA
(annotation only)"
    END
    CLASS
      EXPRESSION /./
      COLOR -1 -1 -1
      LABEL
        TYPE BITMAP
        SIZE MEDIUM
        POSITION CC
        BUFFER 2
        COLOR 0 0 0
        SHADOWCOLOR 218 218 218
        SHADOWSIZE 2 2
        PARTIALS FALSE
      END
    END
  END
  LAYER
    NAME "tgroads"
    STATUS ON
    DATA "tgrds"
    TYPE LINE
    CLASSITEM "Street"
    UNITS DD
  END
  LAYER
    NAME "usa"
    STATUS DEFAULT
    DATA "usa"
    TYPE POLYGON
    UNITS DD
  END
END
Michael Smith, Planner II
City of San Angelo
Planning & Development
325.657.4210 Fax: 325.481.2648
Email: msmith at sanangelompo.org
More information about the MapServer-users
