[Mapserver-users] mapserver4.0 compilation under w2000
Swaminathan, Gayathri
gayathri at ou.edu
Fri Aug 22 11:01:46 EDT 2003
Hi:
This error comes up if regex library is not properly inferenced in your
makefile.vc.
Also you could try compiling your regex one more time, get a regex.obj and
then do make on mapserver...
HTH,
Gayathri
-----Original Message-----
Sent: Friday, August 22, 2003 9:42 AM
To: MapServer Userlist
Cc: kafka at email.cz
Subject: [Mapserver-users] mapserver4.0 compilation under w2000
here it comes again: i try to compile mapserver4.0 on w2000 with
msvc++7. I succeeded a while ago with a mapserv3.7 version. Now i am
stuck with an error related to the regex library:
Creating library mapserv.lib and object mapserv.exp
mapserver.lib(regex.obj) : error LNK2001: unresolved external symbol
_printchar
mapserv.exe : fatal error LNK1120: 1 unresolved externals
Stefan, I cc'ed to you directly since you described the same error some
months ago, did you solve the problem? Or, perhaps some of the
windows-mapserver users has a good idea.
I searched google for a while and only found some references, that
suggested to include a __STDC__ flag for the regex lib, when using it in
cpp code, hmm, but i don't know if that could help in this case.
TIA, Michael
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de/www.zopecms.de
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
