[Mapserver-users] Help !!! Mapscript installation nightmare !!
D. Scott Davidson
davidson at usgs.gov
Fri Aug 22 12:00:42 EDT 2003
For the installation of GDAL, I just did
configure,
make clean
make
make install
but I had to use version 3.8 of the gnu make
Daniel Meyer
<dmeyer at cacheconf To: mapserver-users at lists.gis.umn.edu
irm.com> cc: "D. Scott Davidson" <davidson at usgs.gov>
Subject: Re: [Mapserver-users] Help !!! Mapscript installation nightmare !!
08/20/2003 06:29
PM
Please respond to
Daniel Meyer
-----BEGIN PGP SIGNED MESSAGE-----
Hash: MD5
Hello D.,
Wednesday, August 20, 2003, 2:33:50 PM, you wrote:
Take a quick look at the output from "crle", it sounds like
perhaps the shared library is not in the search path. "ldd"
may also help you here. If the library is not found in the
search path you could either add it to via crle or try
specifying paths manually by setting LD_LIBRARY_PATH when
executing the binary.
I'm curious, how did you go about installing GDAL? When I
try to run configure it complains it cannot locate
gdal-config. I had installed OpenEV which apparently
contains GDAL but not gdal-config. I grabbed the sources
for gdal-1.1.9, but I am missing all the required libraries
need for the different format.
I guess I will rewind and go through all the processes
again and put together some binary packages for Solaris 8
and Solaris 9. I've run into some snags that I am sure
others would love to avoid.
Let me know how things work out.
Daniel.
DSD> Hello,
DSD> I have spent an enormous amount of time trying to get php-mapscript to
DSD> work.
DSD> This has truly been a nightmare.
DSD> I have built php-4.3.2 as part of apache_1.3.26 on Solaris 2.8 .
DSD> This builds fine, and php works.
DSD> I then built and installed mapserver-4.0.
DSD> I configured mapserver with this:
DSD> configure --without-tiff --with-proj=/usr/local/lib --with-gdal
DSD> --with-wmsclient --with-gd=/usr/lib
--with-php=/usr/local/include/php/
DSD> It made fine.
DSD> I then copied the mapserver.so to the php directory, edited the
php.ini
DSD> file.
DSD> When running the phpinfo_mapscript.php test file I get these errors:
DSD> Warning: dl(): Unable to load dynamic library
DSD> '/usr/opt/lib/php/extensions/php_mapscript.so' -
DSD> ld.so.1: /usr/local/apache/bin/httpd: fatal: relocation error: file
DSD> /usr/opt/lib/php/extensions/php_mapscript.so: symbol gdImageSetClip:
DSD> referenced symbol not found
DSD> in /www/htdocs/phpinfo_mapscript.php on line 21
DSD> This has been maddening - does anyone know how to fix this ?
DSD> _______________________________________________
DSD> Mapserver-users mailing list
DSD> Mapserver-users at lists.gis.umn.edu
DSD> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Best regards,
Daniel
CacheConfim
http://www.cacheconfirm.com
dmeyer at cacheconfirm.com
-----BEGIN PGP SIGNATURE-----
Version: 2.6
iQCVAwUAP0QEZgyQdEmcbNM5AQH9gwP/fz1maOqeOzCxFI53Btdrhru8HP1OBwig
emVSaLdNIni62VUJ9G6xqgV9MOuy8eb/TXrRHOkCW5J0+usH/Aqu2Z+OHI08iFwp
DjktFEvyikO15+DZMAkCVPFqDvh3EEcg6Gne1FM1DIqAfor3TRahyX8qOWQTK7jU
71OSczI3Bco=
-----END PGP SIGNATURE-----
